Old 04-07-2006, 11:58 PM
Jcrane88 Jcrane88 is offline
Send a message via AIM to Jcrane88
Ignition Choices
Ok, heres the deal. I've got a pretty good job lined up. Im planning, and starting to collect the parts for a V6-V8 swap. Im planning on getting A 350 C.I. SBC 260 Hp 350 FT/LBS torque with 4-bolt mains (Jegs # 809-10067353 ) Now im pretty confident with picking out the right parts for the motor and putting it in. but im confused about the ignition. Im wanting rev control and be able to plug into my tach. can someone point me in the right direction? Hows this work? battery to igntion module to coil to distributor? any tid bits would be helpful
Thanks
John
1984 Camaro 5.7L 350
700R4
Holley 650 Cfm
Edelbrock Performer Intake-Manifold
Crane Cams Duration @ .050": 204/214 Lift:420/442
Summit HEI Distributor
Hedman Shorty Headers
Hedman Y-pipe
Dynomax Turbo cat-back
NOS Decal
VTEC Decal
Old 04-08-2006, 12:53 AM
Aremy Griese Aremy Griese is offline
Re: Ignition Choices
why would you want a rev limiter? as far as the wiring goes, if your six cylinder is carberated then all the wiring you need is already there. that is assuming youre putting another carberated engine in it. all you realy need to change is the moter mounts, i am not sure if 350 will bolt to that transmission , if it does, good . if not , depending on your gearing in the rear end you may need to get a 700r4 ar a turbo tranny, if you need to change transmissions then youll have to change the drive shaft and the crossmember. another thing , im not sure if the tach will still work properly with this engine swap, i did a swap from a 3.1 to a 350 . and mine still works fine
aremy
Old 04-08-2006, 02:24 AM
Genopsyde's Avatar
Genopsyde Genopsyde is offline
The President
Send a message via AIM to Genopsyde Send a message via Yahoo to Genopsyde
You should get a "Crane" fireball ignition setup. It just wouldn't be right any other way.
Old 04-08-2006, 02:52 AM
wrightz28's Avatar
wrightz28 wrightz28 is offline
is bring'n sexy back
the trams won'r bolt up, you're going from a 60 degree stroke cycle motor to a 90.
Old 04-08-2006, 10:22 AM
thanks for the advice...i know that the trans i have wont bolt up...im getting a heavy duty remanufactured trans (700r4)......i figured im shooting for 3.73 gears.....i have yet to decide if i should old school it , or make everything like it was on a 1984 z28, except for the 5.7 instead of the 5.0, like a 1984 z28 clone..i just wont put any badges on from a z28.. keep it base model looking..either way its going to be carburated......the drivetrain is my specialty, I get lost on ignition/electronics..........can someone tell me the basics of after-market ignition? i'm in no hurry, i'm just making a game plan
700R4
Holley 650 Cfm
Hedman Y-pipe
NOS Decal
VTEC Decal
Old 04-10-2006, 09:35 AM
wrightz28's Avatar
Basicly, if your gonna go with a non-computer controlled carb then the 'aftermarket systems' like a MSD ignition box takes the place of the ECM controlling spark curve.
Old 04-10-2006, 09:42 AM
92zcamaroperson's Avatar
92zcamaroperson 92zcamaroperson is offline
You can take a look into a company called jacobs electronics. I have heard good things about them.
92 z28 camaro 5.7 TPI
current - slp intake runners and base-BBK 52mm throttle body-MSD 8.5mm wires, blaster coil, and 6AL Box-edelbrock headers-160 degree stat.-hotchkis strut tower brace
waiting in the garage - LQ4, milled heads 317 casting (10.5 to 1), hardened pushrods, ported LS6 oil pump, manley dual spings with titanium retainers, MTI X1 cam, hawks longtube headers
Old 04-10-2006, 10:08 AM
i think i understand the basics now. right now im thinking i want to put the v8 in exactly like the 305 "HO" would have just with 45 more cubes...vaccuum hoses, wiring and all.....i'll probably change my mind several times still....
700R4
Holley 650 Cfm
Hedman Y-pipe
NOS Decal
VTEC Decal
Old 05-28-2006, 05:35 PM
FormulaLT1's Avatar
FormulaLT1 FormulaLT1 is offline
Fight the powwa!!!
Send a message via AIM to FormulaLT1 Send a message via MSN to FormulaLT1 Send a message via Yahoo to FormulaLT1
I LOVE my Jacobs Pro Street system. Tons of spark energy more than any other system I looked at (including MSD, Mallory, accel and Crane). It comes as a complete system and it uses the spark plug as a in cylinder combustion tester. Plus I increased the gap from a .055 gap to .075 and no one missfire. I wouldn't normally go that wide of a gap but was just testing shit. Also just for some info, Jacobs was bought out by Mr.Gasket. So you can find info for them now on www.mrgasket.com .....
RIP Hypsi - I just want to express I will never be the same after having lost such a good friend. You meant alot to me and I feel I am a better person for having known you. Til the day we meet again my friend you will always be in my heart.
Mods: Weight reduction (I don't wear underwear)
