Go Back   Automotive Forums Car Chat > Mercury > Cougar
Old 04-07-2006, 10:21 PM
bigcharles bigcharles is offline
Need help with a 92' please
car is trying to go by itself it's idling extremely high, i tried turning down the pin but to not much help. and a white/grayish smoke is coming out the passengar side of the engine down somewhere on the left side in the bottom i'd say of engine, car is also making a bit of water drops to come out the tailpipe, i would dirve to mechanic but with smoke why risk your life please help
Old 04-08-2006, 02:03 AM
KimMG KimMG is offline
AF - Advisor
Re: Need help with a 92' please
Some water (not coolant) coming out of the tailpipe is normal condesation. Does the exhaust smell like coolant? Is the car losing coolant? How's the oil level? Are the fuel lines in good order? Not knowing what is burning, I would suggest having it towed to a shop.
Old 04-08-2006, 10:31 AM
well the car already has an over heating problem and has had one for a while, it seems to me this is a bunch of small problems wrapped into one, the fluid coming out tail pipe is water, just water not really a funny smell but it does smell like car because the water went through the car before it came out the back. The revving is causing the engine to heat up extremely fast which is causing the smoke to come out faster the oil is fine not watery or milky, i think the smoke maybe an oil ring bad or something to do with oil since it is white yet until i sprayed the car out with a hose( i know bad, but when the car first caught on fire we used a fire extenguisher to put it out and had to get the stuff out somehow) and only had the over heating and over revving problem until when i cleaned out the fuel injector body and adjusting the throttle screwto try to make the revving stop
Old 04-08-2006, 10:32 AM
and other than being a little wore looking the fuel lines look fine, im basically trying to stop the over revving then i can get this thing to the machanic without to much smoke and fire coming
Old 04-08-2006, 09:33 PM
AF - Advisor
What caused the fire? Did you fix what caused the fire? If you have a leaking fuel line the car may catch fire again. Fuel dripping onto a hot manifold will burn. How's the coolant level?
I don't know what you mean by "and other than being a little wore looking the fuel lines look fine". Could you please clarify?
Old 04-09-2006, 07:59 AM
i cleaned the throttle body out all the crap from it went down into the side of the engine then the smoke started the fuel lines are old and dirty but otherwise fine
