Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 04-07-2006, 08:49 PM
MexRocket's Avatar
MexRocket MexRocket is offline
Worried about going to far into the HEAD
I am doing a heli coil thingy on my head for the exhaust manifold. I am drilling into the head, (21/64 bit) And I just don't know how to tell what is to far. Then I can't tap it by hand. Bah, I am sure I am just freaking myself out, I jsut don't want to fuck up my head and everything else. thanks
STATUS: Near completion for the Engine
PROJECT BEST 1G IN IL:70% Done
MODS: C2 boost,mbc,B16GEGTurbo,12x28x3x3 FMIC,Ported2gmani,k&n.
Being bought in two weeks: Dsmlink,880's,3"exhaust,piping,suspension,axel,dri lled and slotted brakes.
Old 04-07-2006, 09:07 PM
95_GSX's Avatar
95_GSX 95_GSX is offline
Send a message via Yahoo to 95_GSX
Re: Worried about going to far into the HEAD
Stick something into the bolt hole in the head and mark the depth with tape. Transfer that mark plus a 1/64 to your drill bit(wrap the tape around the bit @ appropriate depth). As long as you dont go past your mark you should be good to go.
Got AWD?
Some people buy super cars, other build them
----Click It, For Mods and Pics----
'95 Mitsubishi Eclipse GSX - For Sale
'05 Volkwagen Golf GLS TDI - My daily driver
'03 Ford Excursion 6.0L PSD 4x4
'13 Ford F150 FX4 SCREW 4x4 3.5L EcoBoost
'08 Buell 1125R
'83 GMC Sierra Classic K2500 4x4 - Future Cummins Swap
Old 04-07-2006, 09:09 PM
MexRocket's Avatar
so what happens if I go to far from that? lol, doesn't the bit also get smaller as you drill?
Old 04-07-2006, 09:13 PM
95_GSX's Avatar
Dude if you cant follow those directions you might want to consider a machine shop.
Also, your drilling alluminum with a steel bit, the minimal amount of wear(if any) to the bit is negligable.
Got AWD?
'08 Buell 1125R
Old 04-07-2006, 09:38 PM
MexRocket's Avatar
well I did that with tape, I have drilled in one hole pretty well, it is still before my tape mark, I am freaking out because well, it got real cold outside, my garage was closed, and I have like no room between and the garage door infront of the car, so im getting frustrated, the tap I have kinda can be hand tightened but it for so much, I think I am rushing it, which is bad, it's my frist time doing this sort of thing, bah just don't want to fuck upp, im going to wait for tommorow to get warmer.
Old 04-07-2006, 10:12 PM
ez1286's Avatar
ez1286 ez1286 is offline
Send a message via AIM to ez1286
You are sofa king retarded. The drill bit gets smaller? Think about it..., if you need help (cause your brain doesn't work right) I'll help you tomorrow. You can use a socket for the tap if that gigantic tap handle doesn't work.
95 GSX:FMIC, 6-bolt, evo 3 16g, 2600 act clutch, 1g bov (crushed), and a 3" turbo back exhaust, dsmlink, dks 272 cams, wideband 02, Coming soon 2.3L Stroker, 1mm oversized valves, crower sprigs. 91 TSI AWD auto, gm 3.5 maf, maft, fmic, emanage, profec e-01, 3" turbo bk exhaust +more little stuff.
http://www.ratemydsm.com/member/ez1286/?member=ez1286
Old 04-08-2006, 10:18 AM
MexRocket's Avatar
yah giaganto doesn't work at all, I gave up last night becasue I was rushing shit, so I thought about it, and went inside, because i don't wanna fuck something up, call me today, I just waited fucking 1 hour for prom tickets.
