Old 04-07-2006, 06:42 PM
Im3good4u's Avatar
Im3good4u Im3good4u is offline
Valve Lash>Immediate Help
Ok recently i posted a thread about how my engine was making a rattleling noise, today a friend told me that it is probably that my car's valve lash is not adjusted correctly.
My questions are as follow:
What is the proper valve lash for a 1994 LT1?
My could have caused this over night disajustment? (A friend said it was my recent change of oil from 10-w40 regular to 10-w30 synthetic)....car has 29k miles after rebuilt.
I was not to sure what the rocker arms were and before speaking to my friend i diagnosed that that was were the noise was coming from. So smart me took the cover off found that indeed some rocker arms had play and some were tight. So yes i tightened it to see if i could remove some play and i did. Cranked up the car, drove around and the noise was still there.
Is my car safe to drive now that my stupid ass messed with the adjustment, Or could this really harm my engine.
Is it a big deal or can i just change the oil back and let it fix itself.
1998 Trans Am Bone Stock...For Now!
Sold 2004 Dodge Ram 1500 QC Hemi W/ K&N Air Filter, Superchips Tuner.
Sold 1994 Firebird Formula W/ Hooker Headers, Magnaflow Exhaust, Ram Air, Fuel Pressure Regulator.
Quiters don't win, Winners don't Quit.
Old 04-07-2006, 06:55 PM
maxwedge maxwedge is offline
A990 racer
Re: Valve Lash>Immediate Help
Get someone to adjust the valves properly.
Old 04-07-2006, 08:21 PM
Mr. Luos's Avatar
Mr. Luos Mr. Luos is offline
Firebird Guy
Sure you don't have a bad rocker?
Stock rockers?
Spinning to a higher RPM than stock?
1999 Pontiac Trans Am WS.6 #1747
Stock'ish'
Old 04-07-2006, 08:30 PM
Im3good4u's Avatar
Yes that probably too but most importantly...is my car driveable
Old 04-07-2006, 08:34 PM
83T/A98Blazer 83T/A98Blazer is offline
I know on the older Chevy small blocks the valve lash is about 1 turn past zero. I can't say for sure that is the case with a 94 but it shouldn't be much different. You need a book to tell you which valves to adjust at #1TDC and at #6 TDC. With the timing mark lined up and the rotor pointing at #1 plug wire set the following valves: Exhaust # 1,3,4,8/ Intake #1,2,5,7. Rotate the engine until the timing mark is back at TDC and the rotor points to #6 plug wire, set the valves: Exhaust # 2,5,6,7/Intake # 3,4,6,8. Turn the nut on the rocker arm out until there is play. Turn it slowly back down until there is no play, you are looking for UP & DOWN play. It still will wiggle and may seem loose, but look for UP & DOWN play. When you reach the point of no play turn it one complete turn further. That is from the book I have which only goes up to 85, mine's an 83 T/A. What I do is, when I assemble an engine I install all the rockers and run the nuts down about 4 threads. That is where you normally end up after going through the above process. The oil shouldn't have anything to do with it, I run 10w-30 synthetic in mine and 5w-30 in my V6's.
Old 04-07-2006, 08:38 PM
Mr. Luos's Avatar
Firebird Guy
I would stay outta the loud pedal until you get it figured out.
You probably need rockers.
Is it a tick? Rattle?
And you are 100% it is coming from the rockers?
Stock'ish'
Old 04-07-2006, 08:58 PM
Im3good4u's Avatar
110% that it is the rockers.
Its been getting progressively worse.
Old 04-07-2006, 09:01 PM
Im3good4u's Avatar
I was told these rockers cant be adjusted so i have no problem... Thank God...Rattle is getting thicker and progressively worse but i was told it is because i have changed to thinner oil. and if it bump it back up it will be ok.....
Old 04-07-2006, 09:11 PM
Mr. Luos's Avatar
Firebird Guy
Probably needs new rockers. Can you turn it over without spark and fuel with the valvecover off?? Make sure the car doesn't fire of course. See if you can see anything loose.
I can see oil making a little difference, but I would think a synthetic would quiet it down, not make it louder. Unless the rockers are dead, and the older oil was keeping them from dying completely.
You are revving higher than stock right?
Stock'ish'
Old 04-07-2006, 10:18 PM
Im3good4u's Avatar
Yes revving higher than stock...but my guages are not accurate so i dont know exactly...RPM and MPH guage in my car off by a little and the rest well i dont trust them.
I was able to shake the rockers with my hands side to side.
And the oil thing is that im in miami and a few mechanics have told me i should berunning thicker oil and they say this swicth is wat finished off the rockers.
Now i dont know if i could just tigthen mine or if i need new ones...
How much is new rockers, and wat part is it? just the taco looking thing on top?
Old 04-07-2006, 10:19 PM
Im3good4u's Avatar
So regardless their saying i need thicker oil 20-w50 because of my temp down here.and it will perserve my engine longer at the cost of a little power and more gas cunsumption
Im going to change my oil on sunday and see if sound gets better.
Old 04-08-2006, 07:04 PM
Im3good4u's Avatar
Luos...
How much are rocker arms and where can i get them
Old 04-08-2006, 07:27 PM
Mr. Luos's Avatar
Firebird Guy
Not sure about the LT1.
Are you looking for aftermarket I assume??
http://www.texas-speed.com/shop/cate...MID=2&catid=52
http://www.thunderracing.com/catalog...vid=4&pcid=108
http://byunspeed.com/index.php?cPath...be3ee9a020c4ca
Stock'ish'
Old 04-08-2006, 09:28 PM
doodad's Avatar
doodad doodad is offline
Send a message via AIM to doodad Send a message via Yahoo to doodad
man, l cant help but l can wish that you will fix that thing soon cheap. hopefully it is not serious.. l know how it feels when some weird noises comes from your car..
Erdal
Old 04-09-2006, 01:40 AM
Im3good4u's Avatar
Thank You!!!
Damn I cant believe i might have to spend 300-400 dollars fixing something that wont even add horsepower.
That shit is depressing.
