Go Back   Automotive Forums Car Chat > Dodge > Ram Pickup | Ram SRT10
Old 04-07-2006, 03:26 PM
ram 50 1989 ram 50 1989 is offline
power steering pressure line
I replaced the pressure line on my 89 dodge ram 50 pickup how do you bleed the line to get the air out thanks.
Old 04-07-2006, 05:34 PM
tony36 tony36 is offline
Send a message via MSN to tony36
Re: power steering pressure line
I can't say difinitively, but it is basically a small hydraulic pump with a reservoir, and it will pump the air out on its own as it circulates the fluid. It's not like brakes.
Old 04-08-2006, 12:56 AM
Stevo2's Avatar
Stevo2 Stevo2 is offline
Here's a generic procedure....
Service and Repair
1. With fluid at room temperature, ensure reservoir is at correct level.
2. Allow fluid to settle for a minimum of two minutes.
3. Start and run engine for a few minutes.
4. Add fluid as necessary, then repeat above steps until fluid level is constant.
5. Raise front wheels off ground.
6. Start engine, then slowly turn steering wheel left and right, lightly contacting stops.
7. Stop engine and check fluid level, fill as necessary.
8. If fluid is extremely foamy, let stand for a few minutes, then repeat procedure.
Jack of all trades...Master of none!
Could someone please fix my Instant Email Notification?
Please get back to us with your fix!
Why did you buy a $40K vehicle and not a $100 Factory Service Manual?
Old 04-08-2006, 08:14 AM
thanks for the info
