Go Back   Automotive Forums Car Chat > Chevrolet > Avalanche | C&K | Silverado | Suburban | Tahoe > Suburban
Old 04-07-2006, 02:46 PM
scca01 scca01 is offline
Blower motor will nto turn off
Hey all,
I have a '96 2500 with the 454. If I use the rear blower (a/c, heat, vent, whatever) it will not turn off when I turn the ignition off. It will continue to run until I either pull the fuse under the hood or the battery goes dead. If I pull the fuse, wait a few seconds, then replace the fuse it will stay off. My guess is a relay somewhere but what do you guys think?
-Chris
Old 04-07-2006, 06:17 PM
2000CAYukon 2000CAYukon is offline
Re: Blower motor will nto turn off
Originally Posted by scca01
Hey all,
-Chris
I agree, sounds like a bad relay.
//2000CAYukon
Old 04-07-2006, 06:40 PM
777stickman 777stickman is offline
It sounds like you've got a relay sticking. There are 3 relays, Low, Med & High. They are located on top of the rear HVAC plenum in the right rear interior wheel well. It's a pain to get that stuff off (been there). When it's uncovered you'll see the 3 relays on top. Don't know for sure which is what. You should be able to touch each one and determine which one is the warmest (current flow) while the fan is running, or pull one at a time to see which one stops the fan from running. Hope this helps.............Steve
57 Chevy 210
65 Olds 442 Convertible (Another one sold)
75 GMC Vandura 3/4 Ton
1999 K2500 Old Body Style Suburban (Gone but not forgotten)
05 Dodge Ram 3500/5.9 Cummins
2012 Toyota FJ Cruiser
