Old 04-07-2006, 11:40 AM
Z28 fan 06 Z28 fan 06 is offline
Oil Lea-Update
Here is the scoop....I replaced the oil sending unit and it greatly increased my oil pressure but it did not stop the leak..........So im in the process of changing the rear main seal and hopefully that will fix the problem.........
any comments????????
Old 04-07-2006, 04:16 PM
cuda_dude cuda_dude is offline
Will Whore For Car Parts
Send a message via AIM to cuda_dude
Re: Oil Lea-Update
how bad is the leak?
1995 Camaro - Z28 - M6 - Hardtop
2007 GMC Sierra 2500HD SLT Classic
-R.I.P. Andy (Hypsi)-
Old 04-08-2006, 05:51 PM
Re: Oil Lea-Update
Well..........it's not to bad but it does leave a small puddle underneath the car when parked....Im thinking its the rear main seal..................
1995 Camaro 6speed
Old 04-08-2006, 07:56 PM
Re: Oil Lea-Update
OK, I only ask because a lot of Camaros have oil leaks, it's pretty common but if it's bad enough yeah you should have it fixed and the rear main seal is pretty notorious for leaks.
Old 04-18-2006, 10:57 PM
rabbitdog rabbitdog is offline
Re: Oil Lea-Update
My 95 has a leak also. I've been researching it and it appears that a common problem is a leaking intake manifold. It leaks at the back where the manifold meets the block. There is no gasket for this area. It is sealed using RTV sealant. I may try fixing it next month when I have a few days off. Some other sites saw it's about a 4 or 5 hour job. That's means it will probably take me a day or 2.
Old 04-19-2006, 06:38 PM
Re: Oil Lea-Update
Ok....That is the first time someone has mentioned that location where the leak could be coming from....I will have that checked out.....and if they say it is a 4-5 hour job, it will definately take me at least a day or two also.........
Old 04-21-2006, 09:00 PM
Re: Oil Lea-Update
Try these sites. They describe the fix for the oil leak at the intake manifold.
http://www.geocities.com/MotorCity/Downs/4013/ol.html
http://www.projecttransam.com/projects2.asp
