Old 04-07-2006, 09:32 AM
kbride kbride is offline
Unhappy maintanance required lite stays on
My maintenanace required lite came on but my van still runs like a top. I called a repair shop and they said they would have to investigate the problem, repair it then reset the lite. Is there a way to check this problem and reset the lite myself? Its a 1990 3.3 liter grand voyager.
Old 04-07-2006, 02:03 PM
RIP's Avatar
RIP RIP is offline
AF -Advisor
Re: maintanance required lite stays on
The fact your light is on indicates the PCM has stored a fault code for you. Not sure about a 1990 but you may be able to download fault codes using a DRBII scanner. Take it to Autozone or the like and they'll do it free of charge and tell you what the codes mean. The scanner will reset the light. Or...for less difinitive codes try this: cycle your ignition switch from off to on (not start) three times leaving it on. Watch your "maintenance light" and count the series of flashes. A code 23 would look like flash, flash, pause, flash, flash, flash. If there's more than one code there will be a longer pause between codes. I think Allpar.com describes the codes. Keep in touch.
Old 04-09-2006, 04:11 PM
Bernard Feltzer Bernard Feltzer is offline
The maintanance light goes on automatically every 60,000 miles on that model to remind you to get the pollution control items serviced.
