Old 04-07-2006, 12:18 AM
Sp3cops70's Avatar
Sp3cops70 Sp3cops70 is offline
Send a message via AIM to Sp3cops70 Send a message via MSN to Sp3cops70 Send a message via Yahoo to Sp3cops70
Question Service Engine Soon???????
I took the car into Autozone and they put the machine on it. It came back with the code PO441. Something about emission purge failure or emission valve purge failure......something like that. What could it be?? Is it easy to fix?? Any help would be great....thanks.
GPGT 1997.
^^^^CLICK IT!^^^^ ^^^^CLICK IT!^^^^
Old 04-07-2006, 12:43 AM
BNaylor's Avatar
BNaylor BNaylor is offline
Re: Service Engine Soon???????
For your model and year GP it is a Evaporative Emissions Control System Incorrect Purge Flow. The PCM will detect a purge solenoid stuck closed by monitoring the Evap. Purge Vacuum switch state when the Evap Purge solenoid duty cycle is > 85%. The switch state is currently low (closed) therefore the P0441 triggers.
Check the vaccum line running from the charcoal cannister and vent solenoid to the purge solenoid located at the engine. The purge solenoid is located in front of the front fuel injector rail and fed vacuum from the throttle body. Also, check the electrical connection at the purge solenoid. You may have a flaky purge solenoid.
Timeslip 08/12/06
AF Community Guidelines
Old 04-07-2006, 01:05 AM
Sp3cops70's Avatar
Red face Re: Service Engine Soon???????
THanks for the advice.....I have no idea where any of this stuff is. Any links to how its done??
Or pics??
Anyone else???
Old 04-07-2006, 01:32 AM
BNaylor's Avatar
Or pics??
Pics??? Service manual might come in handy. If I have time I'll post a pic of the purge solenoid in the morning.
Timeslip 08/12/06
Old 04-07-2006, 11:38 AM
Sp3cops70's Avatar
Question Re: Service Engine Soon???????
Old 04-07-2006, 11:44 AM
BNaylor's Avatar
The evaporative purge solenoid is circled in red. You'll see the vacuum line connections and electrical connection.
Series II 3800 NA L36 Evaporative Purge Solenoid
Timeslip 08/12/06
Old 04-07-2006, 11:53 AM
xochesh xochesh is offline
i have 2001 daewoo nubira and i had check engine light on for some time and one day it just stopped working whail i was driving
i asked one dude to take a look at it and he said that the gas is not reaching pestons he checked fule filter and its good he thinks theres something with injector. is he right or not
tnx for any halp :-)
Old 04-07-2006, 12:22 PM
BNaylor's Avatar
Have you tried posting in the Daewoo forum. See link below. Good luck!
http://www.automotiveforums.com/vbul...play.php?f=732
Welcome to AF!
Timeslip 08/12/06
Old 04-07-2006, 12:39 PM
Sp3cops70's Avatar
So basically just check the hoses that are connected to that solenoid valve??
Make sure they are not ripped or lose? If they are replace...right?
Thats it?
Old 04-07-2006, 12:58 PM
BNaylor's Avatar
Thats it?
Thats correct for a starter. Also remove the electrical connector and reseat. When you pull the incoming vacuum line which routes from the throttle body check for vacuum. I can provide voltages and pins to check at the electrical connector later if you have a mulitmeter.
Timeslip 08/12/06
Old 04-07-2006, 01:43 PM
troy1 troy1 is offline
AF -Advisor
2001 daewoo nubira
I thought they went extinct before 01
Old 04-08-2006, 09:48 AM
richtazz's Avatar
richtazz richtazz is offline
stupidity should hurt
They should have never existed. Daewoo should have stuck to cheap VCR's, not building cars.
Still waiting for the "good old days" I'll get to bore my future grandchildren with!
Old 04-08-2006, 12:10 PM
BNaylor's Avatar
Last I heard Daewoo is part of GM. They make that new Chevy Aveo econobox.
Timeslip 08/12/06
Old 04-08-2006, 03:27 PM
jessep28's Avatar
jessep28 jessep28 is offline
They Chevy Aveo...another fine model in the GM line in the forefront of restoring confidence in the American brand image.
00' Pontiac Grand Prix GT
83,500 mi
Old 04-09-2006, 09:13 AM
BNaylor's Avatar
Thats only the tip of the iceberg. GM has another econobox smaller than the Aveo called the Chevy Spark. Its made by Daewoo too. See link below:
http://news.techwhack.com/3344/daewoo-matiz/
Timeslip 08/12/06
