Go Back   Automotive Forums Car Chat > Chevrolet > Caprice
Old 04-07-2006, 12:32 AM
Cyrix_2k's Avatar
Cyrix_2k Cyrix_2k is offline
Detonation
Anyone else have problems with detonation? My 305 misses fairly often due to this. I talked to my mechanic and he said to check the back plugs, so I did and found that they were running too hot. I replaced one plug with a correctly gapped hotter plug and the car definatly runs better, but still misses sometimes. I guess I need to replace the other plugs now Anyone else have issues like this?
1996 BMW 318i Convertible
1989 Caprice Brougham - 305 V8, TH-2004r - FOR SOLD!!!
Old 04-07-2006, 01:03 AM
silicon212's Avatar
silicon212 silicon212 is offline
Confoundingly Lucid
Send a message via ICQ to silicon212
Re: Detonation
If you're detonating due to the plugs, you need COLDER plugs, not hotter!
Run AC R44T or equiv. If these are hot, try an R43T.
There's lots of things that could cause this, the static ignition timing could be over advanced, there could be vacuum leaks, if it's carb'ed the carb might need rebuilt, there could be carbon in the combustion chamber (GM Top End Cleaner, Seafoam, Water etc). You could also have a plugged catalytic converter (especially consider this if the engine's running hot and power is down).
1988 9C1 - Modified LM1 @ 275HP/350TQ - TH700R4 - 3.08 8.5" Disc Rear - see it at http://www.silicon212.org/9c1!
2005 Crown Vic P71 - former AZ DPS - 4.6 liters of pure creamy slothness!
1967 El Camino L79/M20 old school asphalt raper
Remember - a government that is strong enough to give you everything you need, is also strong enough to take everything you have.
Old 04-07-2006, 11:33 AM
Blue Bowtie's Avatar
Registered Offender
Re: Detonation
You should also make sure the EGR valve and system are operating properly. A functioning EGR can significantly reduce the incidence of detonation.
