Old 04-06-2006, 09:34 PM
92talontsi 92talontsi is offline
Sick TSI NEED HELP ASAP
I have a problem with the idle in my 92 talon tsi. after the car warms up the idle does not hold constant. It goes up and down between about 2 and 1.5 rpm. I replaced the tps and the iac and I still have the problem. PLEASE HELP
Old 04-06-2006, 09:35 PM
crunchymilk55's Avatar
crunchymilk55 crunchymilk55 is offline
Send a message via AIM to crunchymilk55
Re: Sick TSI NEED HELP ASAP
Have you checked the FIAV (fast idle air valve)?
now - 2000 civic
soon - 2002 is300
Old 04-06-2006, 09:38 PM
ned032002's Avatar
ned032002 ned032002 is offline
Besides replacing parts, what have you checked to find this problem? Try the search bar too that might help you out, also please put your car in your sig just so nobody gives you crap for not doing it and welcome to AF.
Old 04-06-2006, 11:26 PM
ez1286's Avatar
ez1286 ez1286 is offline
Send a message via AIM to ez1286
Did you do a boost leakdown test? A boost leak could cause poor idle.
95 GSX:FMIC, 6-bolt, evo 3 16g, 2600 act clutch, 1g bov (crushed), and a 3" turbo back exhaust, dsmlink, dks 272 cams, wideband 02, Coming soon 2.3L Stroker, 1mm oversized valves, crower sprigs. 91 TSI AWD auto, gm 3.5 maf, maft, fmic, emanage, profec e-01, 3" turbo bk exhaust +more little stuff.
http://www.ratemydsm.com/member/ez1286/?member=ez1286
Old 04-06-2006, 11:33 PM
LouieAWDTSi's Avatar
LouieAWDTSi LouieAWDTSi is offline
Most people have the oppisite problem where the rpm's go up and down until it warms up. Forget what its called but dsmparts.com has a part on their website that fixes that problem. Might be related..I'd so some searchin.
--the Cruiser-->97 Spyder GST 5sp ---3 inch exhaust, boost/vac gauge, mbc, greddy turbo timer, greddy fmic, greddy type S BOV, 17in wheels
--the DD-->99 ACURA 3.2 TL
--Sold 92TSi AWD, 6-bolt, auto, evo 3 gt turbo with supporting mods
