Go Back   Automotive Forums Car Chat > Pontiac > Bonneville
Old 04-06-2006, 07:00 PM
GZSMOM GZSMOM is offline
Left Or Right-handed Threads?
ON A 1990 BONNEVILLE WITH A 3800cc V-6, DOES THE CRANKSHAFT HAVE RIGHT OR LEFT HANDED THREADS ON THE END OF IT WHERE THE HARMONIC BALANCER BOLTS ON? IF SOMEONE COULD, SINCE I HAVE NEVER PULLED THIS TYPE OF HARMONIC BALANCER, PLEASE INFORM ME HOW TO PULL AND WHAT TO EXPECT (WITH THE CRANK SENSOR).
THE REASON THAT I AM IN NEED OF THIS INFORMATION IS BECAUSE THE HARMONIC BALANCER IS COMING APART?
OR IS IT?
SINCE THIS PROBLEM HAS STARTED (THE HARMONIC BALANCER SOUNDING LIKE YOU'RE BEATING IT WITH A HAMMER, REAL FAST), I HAVE HEARD A FEW OTHER BONNEVILLES MAKING THIS SAME NOISE. IT MUST BE A COMMON OR REOCCURRING PROBLEM THAT OTHER PEOPLE HAVE RUN ACROSS.
PLEASE HELP ME SO I CAN FIX THIS, (SO ANNOYING) CLANGING UNDER MY HOOD.
THANK YOU VERY MUCH, [email protected]
Old 04-06-2006, 07:16 PM
maxwedge maxwedge is offline
A990 racer
Re: Left Or Right-handed Threads?
r/h thread, go to autozone.com/repairinfo, enter the car info and proceed to repair info for instructions.
Old 04-07-2006, 03:21 PM
richtazz's Avatar
richtazz richtazz is offline
stupidity should hurt
there are two different style balancers for that year. If your's has a smooth face, that bolt is torqued down to some stupid high spec (like 240ft/lbs) and once the bolt is removed, it should slide out. If it has the three threaded holes for a puller to attach to, then the bolt torque isn't as high, but it requires a special puller tool to remove the balancer, as it is press fit over the crank snout.
Still waiting for the "good old days" I'll get to bore my future grandchildren with!
