Old 04-06-2006, 07:16 PM
gunner3oo6 gunner3oo6 is offline
98 windstar headlights
Tried to figure this one out on my own and searching old posts. The DRL's work, parking lights work and flash to pass works. I have no high beams and by the looks of things no lows either. I tried lights on with van running (DRL's come on when started and parking comes on when dash switch is turned on ) and not running ( Turn on dash switch & no head lights just parking ). I have dash lights but the small light to light up the dash light switch doesn't work either.
Dash switch seems to be fine with a test light but I'm guessing at the test sequence, #4 #10 & #38 fuses are good. An older post refered to a ceramic balast mounted behind / under the pasenger headlight. Found it and a wire was broke off. Ford says it's an obsolete part and just bypass ( is only to reduce pwr for DRL's ). Did that and no change.
So i'm thinking it's prob the multi switch but I didn't think the lows ran through that! If it could be the multi, how do I test it and what fasteners are up in the slots holding the column cover ( philips - torx )?
Old 04-08-2006, 10:31 PM
Re: 98 windstar headlights
Problem fixed! I broke down and bought a service manual. The test steps for the multi switch showed it was the cause.
I am posting a new thread " Windstar Headlights Important Read" for some very interesting info regaridng this that all should read.
