Go Back   Automotive Forums Car Chat > Pontiac > Sunfire > General Discussions
Old 04-06-2006, 06:04 PM
|WYG|SS |WYG|SS is offline
blowen head gasket or cracked head?
when i bought the car the coolant tank kept becoming empty and i have added some stuff for like blowen head that u add to the coolant. the coolant must be going out through exhaust or into oil. is this a cracked head aor blowen head gasket? now what ever it is to change it on the engine do u have to start taking stuff off below the temp sensor? (91 Sunbird Le 2.0L, OHC, TBI) this is wut 89 sunbird told me when he had changed his head gasket. now if i do have to do this im going to change the rings on the pistons, do i have to take the oistions out throught the bottom of the engine?
Old 04-06-2006, 06:48 PM
_omen _omen is offline
Send a message via MSN to _omen
Re: blowen head gasket or cracked head?
Wait...you're losing coolent?
Why not check the radiator...it could have a crack in it.
And not to seem like an ass...but could you use the enter key and spell check...it seriously took me 3 times to read that. No offense.
I may drive a slow car...but I can steal your girl...
wait
Nope, can't do that either...damn
Old 04-07-2006, 02:04 AM
89Sunbird 89Sunbird is offline
Check your dipstick. If the oil is milky, then you have coolant in your oil. Cracked head.
When my head gasket blew, the coolant tank filled with oil...
Old 04-07-2006, 01:24 PM
Re: blowen head gasket or cracked head, or something?
i checked the oil and it was fine and like i said i had this problem before when i bought the car. the coolant tank is empty almost and then i look in drive way no coolant on the ground. so the coolant must be going ut through exhaust or something while im going down the road casue i dubt i have a crack in the radiator.
Old 04-07-2006, 04:29 PM
now for the temp sensor spot that has the cap and says pressurized fulid shouldnt u heaaar a little pressure be letting out? casue i think i might have a bad radiator cap.
Old 04-08-2006, 09:54 AM
It's a possibility, I guess
wait
