Go Back   Automotive Forums Car Chat > Chevrolet > Avalanche | C&K | Silverado | Suburban | Tahoe > Tahoe
Old 04-06-2006, 04:48 PM
ctchevy427's Avatar
ctchevy427 ctchevy427 is offline
Power Window Trouble
I am having trouble with the drivers and pasangers side front windows in my 4 door tahoe.The fronts do not go down when you hit either switch just clicking sounds from switch. The rears work fine. The position of the lock switch also does not matter the rears work in either position. I just replaced the switch and nothing has changed. Any Ideas?
Old 04-06-2006, 05:04 PM
pnewcomb1 pnewcomb1 is offline
Re: Power Window Trouble
What year is your truck?
...any tool dropped will roll to the exact geographic center of the vehicle.
Old 04-06-2006, 05:37 PM
ctchevy427's Avatar
Its a 2001
Old 04-06-2006, 07:15 PM
Both of my front 2000 Suburban windows failed within 10 days of each other. I bought the domestic replacements from 1A Auto @ about $100 each. These replace both motor and regulator.
There is a thread on the Silverado Forum that describes the exact same process I used to replace mine.
Before you buy the parts though make sure you have power being delivered to the motors. If not, you have to start looking for the problem fuse/switch/relay.
Again, run the searches and look at results for Suburbans, Silverados, Tahos, Yukons...becase we are all pretty much the same from the front seats forward...
Good Luck!
Old 04-11-2006, 11:40 PM
ksmith757 ksmith757 is offline
I have a 2001 and I had to replace the entire regulator. it was a job rating 5 of 10. I ordered it fromhttp://www.innerauto.com/catalog/Window_Regulator/2001_chevrolet_tahoe.html it was delivered for around $87.00 hope it works.
