Go Back   Automotive Forums Car Chat > Citroen > Xantia
Old 04-06-2006, 03:25 PM
dadotrig dadotrig is offline
Xantia Front Fog light bulb replacement.
Hi everyone,
My car is a (v reg) Citroen Xantia exclusive HDI. One of the front fog light bulbs has blown and I've been told that I will need to remove the front grill facia panel to gain access to the light unit. If this is the case does anyone know how to do this?
Many thanks in advance.
Dadotrig
Old 04-15-2009, 02:46 PM
Tan T Tan T is offline
Re: Xantia Front Fog light bulb replacement.
no need to remove anything. The access to the right hand side head light is kinda obstructed by the ECU box however if you move the two little pipes in the area you should be able to slide your hand to reach the cover clip in the far corner. I managed to do this on my xantia and replaced all bad bulbs. The clip is similar to the one on the other side, so familiarise yourself on the easy one.
