Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Interiors
Old 04-06-2006, 02:07 PM
tr10av tr10av is offline
Send a message via MSN to tr10av
Electronic Hatch Opener/Closer
How would I go about setting up a system that would allow me to pop the hatch and then hit a switch that would open it, hold it open, and then close it all without human assistance?
'87 Chrysler NewYorker
2 12" Ascendant Audio Assasins in Sealed Box
Hifonics TXi 6406 Bridged to 2 Channels
VR3 CD/MP3 Player
COMING SOON:
Component Set
Amp for components
Old 04-06-2006, 02:12 PM
l_eclipse_l's Avatar
l_eclipse_l l_eclipse_l is offline
Re: Electronic Hatch Opener/Closer
With uber amounts of $$$.
'92 3000gt SL
Zoom Stage 1 Clutch
Originally Posted by kjewer1
I disagree. Better is better. Bigger is just bigger.
I just made that up, and I like it.
Old 04-06-2006, 02:34 PM
blk_srt's Avatar
blk_srt blk_srt is offline
Send a message via AIM to blk_srt Send a message via MSN to blk_srt
are you that lazy?
2004 Flame Red SRT-4
|Audiobahn 1200Q|Rockford 602s|Jensen flip out dvd|
Mods:
Old 04-06-2006, 03:00 PM
GTPSPEED GTPSPEED is offline
BOSTONjoe98gs
good idea,,,i was looking for a switch to hit so it lifts me out of my car directly onto my feet..no getting in or out,,,lazy bastard hahahaha j/k
2000 GRAND PRIX GTP RED 14.345 @97.8mph
ubend delete
3in jimmyC downpipe
magnaflow high flow cat
Joeflo CIA (made it myself)
free bypass mod
3.4 pulley from zzp
Gates premium belt
1 step colder plugs
zzp PCM
ss 409 xl turbo mufflers
Old 04-06-2006, 03:05 PM
-Josh-'s Avatar
-Josh- -Josh- is offline
Automotive love doctor
Send a message via AIM to -Josh-
Wouldn't be to difficult, i figure if you can get ahold of a window motor and maybe fashion it to some sort rod that works like an antenna you could make it possible.
Self improvement is masturbation
AF User Guidelines
What is a mippie? - click
Old 04-06-2006, 03:21 PM
EDMUND65's Avatar
EDMUND65 EDMUND65 is offline
Send a message via AIM to EDMUND65
not worth it... wayyy to much $$$$$$$$$$$
Old 04-06-2006, 03:28 PM
blk_srt's Avatar
I guess you could probably fasion up a power antenna motor to open it and close it and just use the stock hatch struts to assist it.
Hey Josh, long time no see
Mods:
Old 04-06-2006, 03:39 PM
crunchymilk55's Avatar
crunchymilk55 crunchymilk55 is offline
Send a message via AIM to crunchymilk55
some guy on the tuners forum has this done. It's the same guy that put around $1000 worth of LED's into his taillights, david I think his name is?
now - 2000 civic
soon - 2002 is300
Old 04-06-2006, 03:41 PM
blk_srt's Avatar
that is alot of leds
Mods:
Old 04-06-2006, 03:47 PM
The hatch is a little heavier than a window...
'92 3000gt SL
Zoom Stage 1 Clutch
Old 04-06-2006, 03:49 PM
-Josh-'s Avatar
You think they build those little motors to be weak? Most have to lift a 5 pound window and do it every day of use through all weather conditions. A simple power window motor would be more than enough if you get enough power to it.
AF User Guidelines
Old 04-06-2006, 03:51 PM
You think they build those little motors to be weak? Most have to lift a 5 pound window and do it every day of use through all weather conditions. A simple power window motor would be more than enough.
I don't see how a power window motor would be able to lift a hatch, which is significantly more weight then a window. Not to mention the increased stress of the angle AND the longer distance it has to travel.
EDIT:
josh can you please lower the size of your sig pic...it's a full screen almost.
now - 2000 civic
soon - 2002 is300
Old 04-06-2006, 04:24 PM
-Josh-'s Avatar
EDIT:
If it's geared properly, like for heavy duty use, then yes it could. Not all window motors are as small as the ones in our eclipses.
Why are we arguing about this again? Someone actually do this who has the time and $400/500 then come back with the evidence.
AF User Guidelines
Old 04-06-2006, 04:29 PM
ez1286's Avatar
ez1286 ez1286 is offline
Send a message via AIM to ez1286
The hatch pretty much goes up on it's own after the first couple inches, I bet even a weaker window motor would work if you had it far enough from the hinge so it had leverage.
95 GSX:FMIC, 6-bolt, evo 3 16g, 2600 act clutch, 1g bov (crushed), and a 3" turbo back exhaust, dsmlink, dks 272 cams, wideband 02, Coming soon 2.3L Stroker, 1mm oversized valves, crower sprigs. 91 TSI AWD auto, gm 3.5 maf, maft, fmic, emanage, profec e-01, 3" turbo bk exhaust +more little stuff.
http://www.ratemydsm.com/member/ez1286/?member=ez1286
Old 04-06-2006, 04:34 PM
wanaplay134 wanaplay134 is offline
Send a message via AIM to wanaplay134
probally a couple acuators and some fabricating probally wouldnt cost that much if you did it yourself just make some brackets and stuff
1992 eagle talon tsi awd
xtd stage 3 six puck/apexi 3' downpipe and exhaust/ngk plugs/taylor thunderbolt wires/manual boost controller set at 20psi/walbro 255 with rewire/autometer boost gauge/turbo xs rfl blow off valve/arp headstuds/ to4b vtrim turbo/dnp tubular manifold with o2 housing and tial 38mm wastegate/eagle rods/ross pistons/acl bearings/arp rod bolts/arp main studs/aeromotive fuel pressure regulator and all stainless lines/aem fuel rail/slowboy street front mount kit
