Old 04-06-2006, 01:04 PM
sierra99 sierra99 is offline
tow/haul not working
I have a 99 silverado 4x4 with a 5.3l that has 118,000 miles. I just noticed the other day that my tow/ haul button is not working....I really do not tow much, but i would like to get it fixed. where does to go from the lever??? is there a sensor or motor to engage this on the tranny somewhere or is it built in the tranny???... is this a major deal or should i leave it alone and deal with it being broken???
Old 04-06-2006, 01:48 PM
silverado122775's Avatar
silverado122775 silverado122775 is offline
Re: tow/haul not working
it is most likely the switch on the lever. it mau also be a fuse too.
2000 Silverado Z71, 5.3L, K&N GenII Air Intake, Y-pipe Exhaust (no muffler), Bosch Platnium +4 plugs, 242k miles and still running.
Old 04-06-2006, 04:39 PM
pnewcomb1 pnewcomb1 is offline
Mine was a broken wire in the steering column...two screws to drop the bottom cover off...orange wire if memory serves...put on a piece of shrink tube...soldered the wire...shrunk the tube...buttoned it back up...
...any tool dropped will roll to the exact geographic center of the vehicle.
The Following User Says Thank You to pnewcomb1 For This Useful Post:
heckufaguy (04-27-2013)
Old 04-09-2006, 06:28 PM
jaxondes jaxondes is offline
Had the same problem on our 2000 gmc work truck - wire was broken at the base of the gear shift.
Old 04-11-2006, 08:08 AM
thanks guys..I will look there....will update...
Old 07-24-2006, 02:05 PM
Dacatocham Dacatocham is offline
What turned out to be the problem. My 2000 chevy silverado z71 pickup tow/haul quit working about a year ago and I blew off fixing it because the chevy dealership didn't seem to know anything about these. Now I need it and want to fix it. The dealer couldn't even tell me where the fuse is located or what it is labeled.
Old 08-04-2006, 08:11 AM
Smile Re: tow/haul not working
I'll be danged. It was indeed the broken orange wire at the base of the gear shift lever. I soldered and insulated and now the tow/haul works again. Thanks.
Old 08-12-2009, 01:24 PM
Mungaman Mungaman is offline
Hey---thanks for the info---my 2000 Chev Suburban tow/haul switch was also a victim to the broken orange wire. Repaired myself and back in business--(by the way, a repair shop wanted $160.00 to replace/repair the problem)
Old 05-31-2010, 07:47 PM
JimMartin's Avatar
JimMartin JimMartin is offline
Just fixed mine today. Both wires where broken. EZ fix! Thanks for the advise!
2001 Suburban 2500 2wd, Billstien shocks, 1" drop brackets in the rear, 285/75R16 A/T, Front and rear 2" hitch
Old 05-11-2011, 10:53 PM
Darto55 Darto55 is offline
Add another broken orange wire to the list. My tow/haul light has not worked since I bought the truck. It's an '01 and I bought it in 2011. I assumed it was something major tranny wise. Googled it an ended up here.
Pulled the boot back and there was the broken orange wire.
Please note the orange wire has two white wires inside. Both wires have to be connected and insulated. I used a short wire pair to exted the wires and make it easier to connect them.
Old 07-15-2011, 12:35 PM
Reinout Reinout is offline
Thumbs up Re: tow/haul not working
Thanks a lot, it was the orange wire on mine also. The lower cover was snapped in place, no screws
Old 02-29-2012, 05:49 PM
19Hillary69 19Hillary69 is offline
Can't disassemble the steering column plastics. Removed the two screws and separated the plastic somewhat but can't see how to get it off the tilt wheel lever on the left. And the part of the plastic under the dash doesn't separate. Lastly, does the bottom plastic come all the way off? Mine is a 2000 Silverado. Thanks in advance. Love the thread. Any pics?
Old 02-29-2012, 06:22 PM
j cAT j cAT is offline
the plastic covers come off with special screw sockets. this does have screws to remove to open the shift lever area to repair the broken tow mode switch wire. [wire was OEM too short]
go to an automotive locksmith for hands on help , if you cannot find pictures or manuals that give this in detailed form.
Old 02-29-2012, 08:25 PM
How does the handle on the tilt lever handle come off? I have the two screws out. I'm a good mechanic and have all the tools to do any thing, just haven't seen how to continue the disassembly. Thanks for the reply.
Joel
Old 02-29-2012, 08:34 PM
This site may be helpful to me....and others.....showing disassembly.
http://www.chevyavalanchefanclub.com...tml#msg1630689
