Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 04-06-2006, 10:07 AM
Big Dogg Big Dogg is offline
Check Engine Codes
Has anyone done any specific repairs involving the P1390 and P0351 check engine light codes? If so, what specifically did you repair in relation to the description given by the code definition? The vehicle is a '96 Mitsubishi Eclipse, 4cyl, non-turbo, manual trans. Thanks for any replies.
Old 04-06-2006, 11:59 AM
nova1313's Avatar
nova1313 nova1313 is offline
Re: Check Engine Codes
whats are the codes descriptions?
08 Kawasaki Ninja 250R - Plasma Candy Blue
07 Toyota Rav4 - Ltd Ed. 6 Cyl AWD
97 Mitsu Eclipse Spyder GS-T 5 Speed
Old 04-06-2006, 01:54 PM
GTPSPEED GTPSPEED is offline
BOSTONjoe98gs
well the 1390,is your timing belt skiped a tooth.
2000 GRAND PRIX GTP RED 14.345 @97.8mph
ubend delete
3in jimmyC downpipe
magnaflow high flow cat
Joeflo CIA (made it myself)
free bypass mod
3.4 pulley from zzp
Gates premium belt
1 step colder plugs
zzp PCM
ss 409 xl turbo mufflers
Old 04-06-2006, 02:12 PM
david-b's Avatar
david-b david-b is offline
Dave is THAT guy
P0351 Ignition Coil A Primary/Secondary Circuit Malfunction
2013 Chevy Sonic 1LZ
75 Monte Carlo
01 Pontiac Grand Am SE - RIP
Old 04-10-2006, 07:47 AM
We replaced the coil and it drove fine again for about 100 miles. Then it started doing the same thing again. The engine starts missing and jerking, then cut off. It starts right back up and runs fine. Sometimes it will run fine for a few days then other times it only runs for a couple of miles and cuts off. On the latest episode, we had cleared the codes after replacing the coil, the check engine light came on and this time it had "3" codes instead of "2". The codes now are 0351, 1390 & 1391. Thanks for all the posts.
