Go Back   Automotive Forums Car Chat > Pontiac > Montana/Montana SV6
Old 04-06-2006, 07:35 AM
blockhead blockhead is offline
99 Montana Load Leveling Module
My self load leveling will inflate but will not deflate (it will stop inflating but not deflate). So eventually the shocks get completely full. I would like to replace the module that controls the compressor and the deflation process. This module is connected to the rear leveling crossbar by a small rod which moves a lever on the module up and down. Depending on the position of this lever: the compressor comes on , shuts off the compressor, or deflates the shocks based on the position of this lever. If anyone knows where I can get a functional replacement for this module I'd appreciate it. Thanks.
Old 04-06-2006, 11:26 AM
Glen_T Glen_T is offline
Re: 99 Montana Load Leveling Module
I assume the dealer price is a lot or you'd just get it from them. You can call some salvage yards and/or search at car-part.com....any chance it is just a bad connection, and/or you sure that it is this sensor? You might have a check valve solenoid in the compressor itself that is sticking shut.....Glen
Old 04-16-2006, 12:51 PM
Denali Denali is offline
Hi,
I have the same problem with my 01 Montana. I also think itīs the solenoid causing this. But I donīt want to buy a new one without being sure itīs the part I need because its Price is more than 100$.
Old 04-16-2006, 06:50 PM
ewertro ewertro is offline
Before going ahead and blaming the module, mine did exactly the same (would pump up but not release) and I found it was a corroded wire right by the connector that attaches to the compressor. Check the wiring first.
Old 04-22-2006, 12:04 PM
Kurt Randolph Kurt Randolph is offline
I Am Experiencing The Same Problem.
Pumps Up But Does Not Release.
I Will Investigate The Wiring Today And Advise.
Hope You're Right On The Easy Fix.
Old 04-23-2006, 07:16 PM
Did you try the self-diagnosis function? Look under the Olds Silhouette forum under "Air Shock Problem", and you'll see the procedure. It works on my 2003, but not sure about the 1999.....I'd be curious to know if it has the diagnosis feature. The fellow I'm trying to help there can't seem to get it to work on his 1998....Glen
Old 09-11-2007, 02:46 PM
sparky63 sparky63 is offline
I have the same problem with my 1999 Montana. Rear shocks pump up ,but never releases. I am not sure what lets the pressure release? Have you had any luck ?
Old 09-12-2007, 01:04 PM
kcarlen kcarlen is offline
Put a tiny hole in the line feeding a the Tee to the shocks.
It will self regulate.
