Go Back   Automotive Forums Car Chat > Chevrolet > General Discussion
Old 04-06-2006, 02:50 AM
jamesmetairie jamesmetairie is offline
change oil dash light=
hi dash light reads = change oil soon. how can i turn it off. thanks.
Old 04-06-2006, 04:35 PM
abaird abaird is offline
Re: change oil dash light=
Turn the key to the run position and push the pedal too the floor and let up (I think 5 times) Then start the car, should be good to go.
2009 Silverado 1500
2002 Camaro Z28(rebuilder)
2005 Yamaha GP1300R
Old 04-06-2006, 08:35 PM
gmtech79's Avatar
gmtech79 gmtech79 is offline
It varies on different vehicles. If you have a GMT800 turn the key to run a push the accelerator to the floor three times within 5 seconds.
Old 04-08-2006, 03:18 AM
Smokefan20's Avatar
Smokefan20 Smokefan20 is offline
Send a message via AIM to Smokefan20 Send a message via Yahoo to Smokefan20
Question Re: change oil dash light=
I always heard you NEVER pump the gas pedel on a fuel injected vehicle (when its not running). Is this a myth? Is this another thread maybe??
Old 04-08-2006, 01:36 PM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
Well that all depends.
If you want the oil change light out you do it.
If you want it to start right you do not.
But if you have a foot that is pump happie.
Just roll the window down and step outside of the car and reach in threw te window and turn the key on and start thes car before intering.
But in case your car get flooded you can hold the gas pedal to the floor and it will enter a clear flood mode in the pcm that will shut of fuel and clear flood.
MT
MT
Old 04-09-2006, 05:13 PM
gmtech79's Avatar
yea, you dont want to pump it while you are cranking the engine. you can pump it as much as you want when you are not cranking it, all you are doing is moving the throttle blade.
ASE Master
ASE Advanced Engine performance
GM World Class Technician
1978 Pontiac Trans Am
1984 Monte Carlo SS
1991 GMC C1500
2002 Pontiac Grand Prix
Old 04-10-2006, 01:41 AM
Smokefan20's Avatar
Ahh, I see. THAT makes sense. Thanks for clearing that up for me GMTech.
Later!
Old 04-12-2006, 11:54 AM
Blue Bowtie's Avatar
Registered Offender
And, if it happens to be a '94, there is a RESET pushbutton alongside the fuse panel. Subsequent years used the KOEO/Throttle method as previously described.
