98 cavalier2.4 trans won"t shift up (ERLSfuseisgood)
My transmission well not shift up it stay in first gear.ETS,ABS,BRAKEandENGINE also my AC won"t kick in. check all relays and fuse. OBII reads P758,P753and P1860. I'am down to ERLS fuse.But the is fuse is good. Where the ERLS fuse relay is located at? If its has one.and where the power come from? Where can I get wire diagram online for free? please HELP! I'am going crazy here!!!!
Re: 98 cavalier2.4 trans won"t shift up (ERLSfuse)
Sorry I can't tell you where the ERLS fuse is, but it sounds like just a major wiring issue, shorts or opens, something along those lines. I recommend visually inspecting all of the wiring as best you can. Make sure all of your grounding straps are in place as well, if they are not it can "confuse" the PCM. If I remember I can do checking on this problem within the next few days (it might be a good idea to remind me) and there is a good chance I can come up with a direction for you to go.
well i had a 89" nissan pulsar...what a hell of a a car...but anyways i had to replace the motor and or trans mounts because it wouldnt shift up and hold in a high gear...or when i get it in gear it would pop out if i took off..so look into your motor and trany mounts!
the other problem sems to be electrical look into replacing ur fuses and fuseable links! |
