AC recharge
Soo, summer is right round the corner and my AC needs a recharge. The pump cycles many times when engaged, and does not get cold. I have a R134 recharge kit that came with a pop on pressure gauge. Problem is, it doesn't fit any of the two AC ports on my '01 sable. The port out by the accessory belt with the black cap is too big, and the one up by the firewall on passenger side with green cap is too small?? Do I need something special to recharge the AC like a ford coupler or something? Any help would be appreciated. Thanks all!!
Re: AC recharge
If it needs a recharge, it has a leak. If cooling is important you ought to get it serviced, lots of A/C service specials this time of year. Couple years ago I had my '02 hooked up to a shop recharge machine, takes the old refrigerant out, pulls down a vacuum and recharges it to the amount on the hood label. Great improvement and has worked well ever since.
Re: AC recharge
I know Tauruses are notorious for having leaks in the AC system through the seals or bad o-rings. I just want to recharge myself with some R134a with leak stop in it. I hate taking my car anywhere that I no longer have direct control over who's monkeying with it, hence my shade-tree mechanic equipped garage. I read that on the older style cars, it was under a plastic shield at the base of the windshield that had to be removed. Has this carried over to the newer body style vehicles?
Re: AC recharge
I know this is no help to answer your question but......
Hope you check it for leaks because I'm sure you know that whatever you do it will leak right out again if you have one. Similar to you, I don't like to turn my vehicle over to someone I don't know but don't think it's practical to buy the recharge machine for probably a one time use. When they did the recharge on mine I stood right there and watched. I've never heard that Ford vehicles were "notorious" for any more A/C leaks than any other brand. If you don't evaculate and draw a vacuum in the system it won't be as efficient as if you did. R134a systems are not as efficient as the outlawed Freon, depending on where you live you might or might not need that extra efficiency. It turned out that my A/C charge was OK, my problem was a stuck diverter door. The car had been sitting several months. A smart service tech exercised the hot-cold control back and forth a few times and it was fine. |
Re: AC recharge
Thanks for the replies, but really, I just want to know the location of the recharge port. I've got a pressure tester that I want to hook up and make sure its just a leak or low, and not something else before I take it anywhere to have it looked at by "professionals"
Re: AC recharge
You know what the pressure readings should be? If you aren't satisfied with the answers here you might want to post @ www.batauto.com. Lots of tech's hang out there.
Re: AC recharge
If you have one of those pressure gauges that come with a recharge kit, you are not going to accomplish anything. You need a set of A/C gauges to diagnose the problem. If you insist on using the little mechanic kit in a box, the low pressure port is close to the accumulator on your vehicle. There is no special adapter for Fords. All the 134 connections are the same as far as I know. The green cap you are talking about is your evap test port. However, I accept no responsibility for any damage or harm that comes to your vehicle or you.
Being way2old is why I need help from younger minds The sooner you fall behind the more time you'll have to catch up. ![]() HEY Y'ALL--READ THIS Here are some of our old vehicles for sale.
Re: AC recharge
Green port too small, black port too big, these are the ONLY two AC ports visible under the hood. Has anyone here actually recharged their system themselves? I've got a can of 134a and a pressure tester, neither will fit the two visible ports on the car. So unless its hidden somewhere, then I need some sort of adapter. My tester has successfully recharged all of my previous cars, even those with leaks (that stopped after I recharged with the leak stop R134a canisters). I never take my cars to the shop, preferring to do all the maintenace and wrenching myself. I've just never owned a newer ford (my last experience was with a late 80s T-bird), so i'm not down with their engine layout. If anyone knows for sure where the port is, i'd like to know. Otherwise, when my service CD arrives in a few days, I will post back where it is so everyone knows for future reference. Thanks again. |
Re: AC recharge
Thanks |
Re: AC recharge
Had a 97 and the fill port was up against the firewall passenger side. The recharge kit fitting was the right size.
Re: AC recharge
Thanks, that helped confirm what I found. I filled it up but i think i only filled the hose to the a/c and not the a/c itself because it didn't seem to turn on when I had it turned to Max Cool. I assume this means something is wrong with the compressor but I was wondering if the a/c will not turn on because there is not enough coolant in the system and I don't see how it adds coolant when the a/c does not attempt to run and "suck" in the coolant.
I'm not sure how the system works but I wonder if i am stuck in a catch 22 or if something else is wrong with the system. |
Re: AC recharge
Is the pressure switch connected? Do you know if the A/C ever worked since you've owned it? If the pressure switch is not plugged in, the compressor won't run even if the system is full of R-134a refridgerant. Or, the pressure switch could be bad.
You really need to put a gauge on both the high and low side to see what both pressure are. Having that information will help you understand what the problem may be as well if the pressure switch is working. -Rod |
Re: AC recharge
Re: AC recharge
Did you fill your system while it was running, because that is very important? I hope you are right that you needed refrigerant as overcharging it and running it is bad, worse is you put it in while not running. That would put liquid refrigerant straight to your compressor. Not good. Hopefully it will go to gas before you run it. Did you see the ac compressor turn on and off like it was trying to work BEFORE adding the refrigerant? Try running the defroster to see if the compressor comes on. To be clear, the compressor comes on when the clutch at the belt slaps on and the end of the compressor turns. If it does not turn, then you are looking at an electrical problem primarily. The compressor will come on irreregardless of the refrigerant as long as all of the electrical run circuits are completed when starting for the first time. If the pressure switches sense a no run condition like too high pressure after trying to run or run for awhile, it will disconnect the run circuit with the high pressure cutout switch. The compressor will cycle on and off according to the low cutoff and high cutin cycling pressures. Typical pressures are 45 psi on and 25 psi off and yes the on and off pressures are counterintuitive. This switch sensor is either next to the accumulator/drier or screwed into it and the low side fill/test port should be very close by. The high pressure switch is attached to the suction/high side pipe most likely close to the compressor and radiator. It would also be near and on the same line as the larger test port found in the front and above the compressor. Your system when properly charged should give you in the center air duct about 30 to 40 deg F air temp colder than the uncooled inside or outside air temp at Max AC. You can also check it be feeling the pipe to the accumulator. It should get very cold, swetting first and frost if cold enough. You NEVER want the frost going all the way to the compressor. That means it is overcharged or the low pressure switch isn't shutting off the compressor when it should. Compressors can't compress liquid refrigerant only gas.
Re: AC recharge
Basically, you need a gauge to test the pressure switch. The clutch cycle switch opens(off) at low pressure and closes(on) at a high pressure. The cheap gauges that are part of a recharge kit could give you an idea if the switch is working by connecting it to your low side port by the accumulator and watch the pressure swing as the clutch cycles on and off. Roughly it would go between 25 and 45 psi, though I've seen lower. If you think it is not working at all, you can TEMPORARILY put a jumper wire across the two wires that connect to the pressure switch at the disconnected wire connector. I'm pretty sure you should also be able to test for power on one side of the switch and to the other side if it is closed. Power flows from there to the high pressure switch (that too you can wire jump to verify it not working) and finally to the clutch on the compressor itself and then ground. Wired in parallel with the compressor is a diode to ground not letting any current to ground, just to let you know that it is there. If it is an issue hopefully Rod can chime in, because I don't know why a diode is needed there.
