Old 04-05-2006, 11:28 PM
h22hatch91 h22hatch91 is offline
coilovers
well i have some coilovers and i need to adjust them and i need to loosen the screw, so i can adjust it up and down. well i tried to and i looks like it is rusted, i have tried wd-40 and it isnt really working, is there anything else i could try to break the rust...........thanks
Old 04-06-2006, 09:05 AM
turtlecrxsi's Avatar
turtlecrxsi turtlecrxsi is offline
Send a message via AIM to turtlecrxsi
Re: coilovers
Spray WD-40 liberally and jack your car way up in the air. You took your wheels off right? I know you don't have to in the front but I've always had to in the rear.
2008 KIA Spectra5 SX
2010 Honda CR-V EX
Old 04-08-2006, 01:35 PM
Concept Tuning's Avatar
Concept Tuning Concept Tuning is offline
Re: coilovers
I usually spray mine with WD-40 after I wash it weekly. Helps prevent future problems.
Old 04-11-2006, 06:32 PM
bambam89lx's Avatar
bambam89lx bambam89lx is offline
AF - Advisor
Send a message via AIM to bambam89lx
Re: coilovers
heat it up with a torch, just don't heat the shock up too much.
Jumper harnesses, mpfi conversions, engine harness conversions, vtec subharnesses, etc.
The absolute lowest prices at the absolute highest quality. Trusted. Guaranteed.
Click the image above to visit our online store!
Hastings Bseries and Dseries piston ring kits (inc. ZC) - $49 shipped
Old 04-11-2006, 06:40 PM
FrodoGT's Avatar
FrodoGT FrodoGT is offline
Re: coilovers
Try some liwuid wrench man..or penetrating lube (same stuff), and a little bit of uhh..shock force I used two very large prybar screwdriver things...worked for me, car was actually sitting almost an inch lower on the right side and 2 inches higher in front! After the lube use some heat, but careful..that stuff is really flammable!
Cheap, Fast, Reliable..Pick two
Current project:
Rio Red 91 hatch.
A6/Z6 build, Hondata S300, Tokico illumina/Ground Control.
"I'd rather run 12's on steelies than 15's on rotas."
Old 04-11-2006, 08:36 PM
Hybrid1990crx's Avatar
Re: coilovers
get a impact screwdriver. the kind you hit with a hammer.
Old 04-12-2006, 01:42 PM
amy@af's Avatar
amy@af amy@af is offline
Traffic Directing Admin
Send a message via Skype™ to amy@af
Re: coilovers
or any big screwdriver.....DON'T HEAT!!! a screwdriver and a hammer!!!!!
lets think about this...a torch + gas struts =
"hi! my name is Lady, and i'm a HONDA-holic"
..don't make me send Setanta over in his Waambulance to give you an aloe tissue for your sensitive nose!
*~ ~> USeR GUiDELiNeS*<~ ~*
I <3 the G Ride ~*~ I <3 OLD SKooL
