Old 04-05-2006, 09:35 PM
legend1011's Avatar
legend1011 legend1011 is offline
How to wash engine without blowing it up? Please let me know
I just saw the civic again tonight and the engine looks dirty; Is there a way using degreaser and car wash wash to wash the engine out without shorting anything out or damaging parts?; It does not look as "technical" as newer cars so it may lack the stuff that does get shorted; Please let me know; I don't want to fry anything
Thanks
Old 04-05-2006, 10:29 PM
CivicSpoon's Avatar
CivicSpoon CivicSpoon is offline
There is no Spoon
Re: How to wash engine without blowing it up? Please let me know
Plastic wrap and tape; over as many connections as possible. Then get some Simple Green, spray her down and do some minor scrubbing, then hose it off.
Old 04-05-2006, 11:10 PM
legend1011's Avatar
Well After searching this and others forums I concluded that it is safe to do and more easier than I imagined.
Basically,
You cover the distributer air-tight with a grocery bag of your choice and then hose it down. Just about everyone says the electrical is air-tight and not to worry; they even claim that they have not had a single problem.
One thing that I have heard that I never would have thought was to do this while the car is running. I would have probably done the opposite, but anyways, it is good to know.
Thanks for your info
Old 04-06-2006, 12:18 AM
FrodoGT's Avatar
FrodoGT FrodoGT is offline
Yeah youve got to gether good and warm, itll definately help loosen some grime.
Cover it liberally with simple green (undilluted), and use brush to scrub her real good, then pressure wash off. then start it up again and let it steam off.
Cheap, Fast, Reliable..Pick two
Current project:
Rio Red 91 hatch.
A6/Z6 build, Hondata S300, Tokico illumina/Ground Control.
"I'd rather run 12's on steelies than 15's on rotas."
Old 04-06-2006, 12:59 AM
allstar323 allstar323 is offline
even with a battery it's okay? I'm not much for electricity, or how it works..but I've always been afraid of electrocuting myself or something. Do I warm it up...and then remove the battery?
Old 04-06-2006, 08:07 AM
turtlecrxsi's Avatar
turtlecrxsi turtlecrxsi is offline
Send a message via AIM to turtlecrxsi
You don't have to remove the battery. Just don't touch it while your spraying water on it.
2008 KIA Spectra5 SX
2010 Honda CR-V EX
Old 04-06-2006, 01:36 PM
FrodoGT's Avatar
Water wont be able to make a connection that far across your terminals, dont even sweat it.
Current project:
Rio Red 91 hatch.
Old 04-06-2006, 03:02 PM
Tony's Avatar
Tony Tony is offline
TLD Member #1
Send a message via AIM to Tony
You shouldn't even have to worry about taping or wrapping anything up, not even the distributor. When you wash it, I would leave it running, just incase you do have a little crach in your distributor cap, which in that case you need to get another one anyway. If you leave it running and it starts cutting out, its because there is a crack in the cap, other than that, everything else is fine. As for getting shocked from it, never had it happen while washing, done it several times while wiring since I wire with the battery connected, but just usually cases a spark and scares me, never hurts....But im just crazy like that, I like testing things as I'm doing it.
Tony
91 Civic Sedan DX - Stock 287k Miles
Old 04-06-2006, 11:59 PM
Concept Tuning's Avatar
Concept Tuning Concept Tuning is offline
Get one of those little hand steamers. Those things are great for cleaning up your engine bay.
Old 04-07-2006, 12:28 PM
civic_boy91's Avatar
civic_boy91 civic_boy91 is offline
Send a message via AIM to civic_boy91 Send a message via Yahoo to civic_boy91
they say not to steem clean your engine ...water may not get in but steem could... just get a pressure cleaner, cover your intake and distributer and blast that bitch... the worst thing that happend to me is not covering the distributer....it wasnt major though...just a litle of water in the cap. it made the car run like crap.
_________________________________http://VelocityFactor.com________________________________
1990 si hatch
b20b si tranny
megan race header 2.5 custom exhaust
50 shot
integra da rear disk (w/ 4040 valve)
powerslot rotors and barded lines all around
1994 Dx hatch
stock
Old 04-07-2006, 07:11 PM
Tony's Avatar
TLD Member #1
Oh yea, cover your air filter if you have an aftermarket intake installed.
If your cap is sealed good and don't have any cracks in it, you won't run into that problem. Ive had that problem once, just replaced the cap and didn't have the problem again.
Tony
Old 04-07-2006, 07:25 PM
livinincalifornia livinincalifornia is offline
Send a message via AIM to livinincalifornia
doing that killed my distributor over a period of about 5 months, it was real bad then it was fine for a few months then eventually the coil had something growing in it from standing water that got inside and was an expensive replacment for the whole distributor (honda oem dizzy's are 800 dollars, but you can get some cheaper one's)
Old 04-07-2006, 09:24 PM
jeef jeef is offline
Send a message via AIM to jeef Send a message via Yahoo to jeef
few things, One never ever do it while your engine is really hot, warm is one thing hot is another... hot engine plus cold water can equal warpage
Two, if your dist. does get wet in side just pull the cap off and spray it with a crap load of WD-40.
a lil tid bit, Wd-40 came from an oil rig looking for a water displacing agent, and on the 40th attempt they figured it out...
90- crx si w/ a D16a Vtec and a few goodies, oh and 60k miles on it heh
Old 04-07-2006, 11:30 PM
FrodoGT's Avatar
denatured alchohol displaces water quite well too, then it just evaporates...
Current project:
Rio Red 91 hatch.
Old 04-08-2006, 12:08 AM
it also makes a great fuel for a stove made out of mini webber grill, tin can, cotton, and tee shirt during hurricane season!
