Old 04-05-2006, 06:29 PM
dk05 dk05 is offline
BRAKE warning light
Ever since I got my car back out of storage the BRAKE warning light on the dash has stayed on. First thoughts were that someone pulled the E-Brake and it did not snap back. I don't know for sure if that's the case, but I did go under the car and pull back on the cable by hand. Obviously that did not work. Next I thought that maybe the fluid was low, which it was, so I added about 3-4oz or fluid, still didn't help. The brakes still respond the same as before (not very great...) but the light was never on before. Both the front and rear pads look ok from what I can see through the rims. I cannot see any fluid leaks under the car when I press the pedal down. The pedal increases pressure with the car off by pumping it, but when on if the pedal is hit slowly it sinks to the floor pretty much, if it is hit fast it grabs about 1/2 way down then sinks to the floor. The car can stop really good yet, but like I said, the pedal is way low. If anyone has any ideas or has had a problem like this before your help would be greatly appreciated. Thanks!
Old 04-05-2006, 06:33 PM
Savage Messiah's Avatar
Savage Messiah Savage Messiah is offline
Send a message via AIM to Savage Messiah Send a message via Yahoo to Savage Messiah
Re: BRAKE warning light
well first off make sure your 3rd brake light isnt out... but because of the pedal situation i doubt thats it.
Check your master cylinder, and also if you have it check your ABS components
97 Camaro - 2.077 60', 14.745 @ 92.20 - still down, one year later.
194k miles-160* thermo-V8 shocks/springs (V6 rear springs)-3" Magnaflow !cat (3" dynomax bullet) back-SLP CAI-stock boxed LCAs-poly tranny mount and torque arm bushing-custom HPTuners tuning-4.10s/eaton/TA girdle-3.5" alum DS-spohn LCA brackets-prostar skinnies
179.75 RWHP, 204.52 RWTQ
ON ITS WAY: MORE
R.I.P. Andy
87 Benz 190e - DD
01 EX250 - still gotta get my license for this thing
Old 04-05-2006, 08:26 PM
Aremy Griese Aremy Griese is offline
look where the master cylinder bolts to the booster. if fluid is running down the booster its the master cylinder. other then that the only other thing i can think of is a leak somewhere else or the lines simply need to be blead. the break light usualy only comes on if there is a significant loss in preasure.
if its the abs i would think that the abs light would come on
aremy
Old 04-05-2006, 09:49 PM
97cavalier's Avatar
97cavalier 97cavalier is offline
ya, bleed it first, then see what that does.
95 Z71 Silverado 4x4 ext. cab
Mods- Flowmaster Exhaust,Intake
Old 04-06-2006, 02:11 AM
No 3rd brake light on the car or ABS, it's an 85. I will bleed them out, that is actually the next thing I was thinking too. I just don't understand why it would come on after being stored for the winter, yet the brakes do not behave any differently. I still think maybe someone pulled the E-Brake and it did not release completely, but then again, I would think that would slow the car down. I will bleed it out this weekend probably, cause that is the next time I have off work for a while. I'll post back after I do that and maybe change the pads while I am at it if I have the funds. Thanks.
Old 04-06-2006, 08:51 AM
wrightz28's Avatar
wrightz28 wrightz28 is offline
is bring'n sexy back
I think your primary piston cup in the master dried up a bit and quit after sitting. If you had to add that much fluid, it almost confirms it along with the pedal travel. If it isn't visually leaking from between the master cyl. and booster, than chances are you have a vacuum booster loaded with the "lost" brake fluid. You could pull the vacuum hose off and check for signs of fluid to verify.
Old 04-07-2006, 01:36 AM
What would the solution be if this happens to be the case? Drain the booster?
Old 04-07-2006, 09:42 AM
wrightz28's Avatar
Well vacuum is gonna take care of that for you for the most part. Hopefully it just didn't do any damage to the diaphragm that sepertes the vacuum from atmospheric pressure. boosters are kinda pricey.
