Old 04-05-2006, 04:34 PM
maureengill maureengill is offline
How to Replace Air Filter?
Hey all,
I need to replace my air filter and am looking for advice on what air filter to go with....also if its something i can DIM.
Thanks,
Maureen
Old 04-05-2006, 06:30 PM
BNaylor's Avatar
BNaylor BNaylor is offline
Re: How to Replace Air Filter?
In the order of preference I'd recommend the following:
AC Delco (OEM)
Purolator
Fram (last resort)
The filter is easy to replace. Just pop open the hood and prop up. On the driver's side of engine is the black air box. There are two screws holding the lid on. You can use a cross tip or flat blade screwdriver. Turn counterclockwise until screws are loose. The top of the airbox needs to be lifted up so you can access the air filter to replace. You may need a second person help hold the lid up which will be restricted by the air intake ducting.
It makes it easier to properly install the replacement air filter. Good luck!
Timeslip 08/12/06
AF Community Guidelines
Old 04-05-2006, 08:53 PM
vamc's Avatar
vamc vamc is offline
I like fram and stp. thats my preferance.
Old 04-05-2006, 11:37 PM
nqc2k nqc2k is offline
Hey, quick question, I bought my car with 60k miles, i replaced the air filter at 100k.....i got 25 miles per gallon average before, now i get 20 mpg, could i have bought a bad filter? I now have 105k and its about 20 mph still.....should I buy a new filter or could somethign else have hurt my mileage? its a 99` 3.4 and I don't beat it.
Old 04-05-2006, 11:51 PM
BNaylor's Avatar
There was an article was posted here a while ago concerning a test with various air filters and a K&N. The OEM AC Delco performed the best. It had the best airflow and durability. No guarantee that will help but it won't hurt.
Timeslip 08/12/06
Old 04-06-2006, 12:14 AM
JTrujillo86 JTrujillo86 is offline
When you hit 100K miles, did you change the plugs and wires?
- Jeremy
Old 04-08-2006, 03:17 PM
Thanks for the help...that was way too easy I can't believe they charge 19 bucks to buy and install what cost 8 bucks and took 2 minutes.
Maureen
Old 04-08-2006, 04:41 PM
PotIsYourFriend PotIsYourFriend is offline
Maureen
Wait until you want to change something as easy as a thermostat
Old 04-22-2006, 12:28 AM
procrstinator procrstinator is offline
or spark plugs for that matter .took me 2 hrs the 3 on back side are a b.....
Old 02-16-2007, 08:37 AM
...but your name is procrastinator
