Go Back   Automotive Forums Car Chat > Oldsmobile > Cutlass Series
Cutlass Series Includes Cutlass Ciera, Cutlass Cruiser, Cutlass Calais, Cutlass Supreme, Custom Cruiser, as well as the GM N-Body subforums.
Old 04-05-2006, 03:56 PM
MandaCHase's Avatar
MandaCHase MandaCHase is offline
Send a message via MSN to MandaCHase Send a message via Yahoo to MandaCHase
Gas Fume Smell
Hi everyone ~
I'm clueless and back again, because I've been burned by nearly 4 mechanics in this area already, all giving me different ideas on what's wrong with my car - I'm very hesitant to take it back in the shoppe again unless absolutely nessacary.
I started smelling a strong odor of gas while standing outside of my car about 4 days ago - my gas cap is on the driver's side and that's where I always smell it when getting into the car, I checked the cap and it's on tightly. I've placed cardboard all around under the car (note I'm not mechanic worth here ppl ) seeking leaks, checked the gas gauge for movement and nothing.
So I'm at a bit of a loss....
It's SUPER strong today.. haha. I don't know if it's just me or what.. and when I was idling waiting for my son all I smelled inside the car was gas.. it was so bad I had to get out.
The neighbors must think I'm crazy because everyday I've been practically crawling under the car just waiting to see something.. But I haven't seen anything on the cardboard.
Any ideas on maybe what this *MIGHT* be? What I Could check out?
1995 Cutlass Supreme Convertiable v6 3.4L
Thanks SO Much.
Old 04-05-2006, 06:17 PM
GTP Dad GTP Dad is offline
Pontiac Guy
Re: Gas Fume Smell
With the car totally cold open the hood and start the engine. Look at all the connections leading to the fuel rail on your car. I suspect you have a leak in one of the connectors on the fuel lines under the hood. Since gas fumes can travel a long way I really don't think the problem is at the gas filler cap but rather at one of the connections either in the engine compartment or at the fuel filter or fuel pump.
When you look at the car when it is cold you may actually see the fuel dripping. If you find a leak get it fixed immediately as it could cause a fire. You may want to look at the area around the fuel filter and the fuel pump as well doing it while the car is cold. I don't know if you will find it or not but at least it doesn't cost anything to try.
Good Luck!
Old 04-05-2006, 06:26 PM
nifib nifib is offline
Re: Gas Fume Smell
inspect fuel injector, make sure connections are good. inspect filter for leaking fuel filter or fuel filter connection, inspect fuel tank for punctured or damage which I really doubt its the tank because you said no leaks. Try it its probably one of those. parts may even need replacement.
Old 04-06-2006, 06:47 AM
MandaCHase's Avatar
Re: Gas Fume Smell
Great thanks for the input guys I appreciate it... =0)
Old 04-08-2006, 08:08 AM
MandaCHase's Avatar
Re: Gas Fume Smell
Just wanted to note that I fixed the probelm... the seal at the top was rusted - for some odd reason though it was only leaking when I was parked on a hill or if the car was tilted to the back. I had him check my lines & sending unit as well and he said those are fine. They replaced the tank - is there anything else I should have checked pertianing to the gas leak or fuel in general?
Old 04-08-2006, 08:21 AM
Pontiac Guy
Re: Gas Fume Smell
Not really but you may want to change the fuel filter if it wasn't changed recently. Just a maintenance item.
