Old 04-05-2006, 12:24 PM
SiggyBaby SiggyBaby is offline
Strange noise when A/C is on in my '90 Accord
When I turn the A/C on in my '90 Accord 4-cylinder LX sedan, it makes a loud whining noise. When I turn it off, the noise goes away. The car drives just fine with the A/C on. I assume this is something with the A/C compressor. Anyone know exactly what it is and what is involved in fixing it? Thanks in advance!
2000 Chevrolet Camaro Z28 A4 - Light Pewter Metallic
2004 Chevrolet Cavalier Coupe A4 - Dark Green Metallic
1990 Honda Accord LX Sedan M5 - Burnt Gray Metallic (My daily driver)
Old 04-05-2006, 08:23 PM
AccordCodger AccordCodger is offline
Re: Strange noise when A/C is on in my '90 Accord
If it's the compressor (which it sounds like it might well be) then the only fix is a new compressor. Not cheap. Does the AC work? If it does, you might as well keep driving until it gives up altogether.
Old 04-06-2006, 07:42 AM
Yes, the A/C works just fine. I had to give it a charge several months ago because I was nearly out, but since then, it gets good and cold.
Old 04-06-2006, 12:35 PM
mpumas mpumas is offline
The whining could be a loose belt or even an overcharged system putting an extra strain on the belt system.
Old 04-06-2006, 12:40 PM
On the compressor? I have taken the car to a local Honda/Acura repair shop that specializes in only these makes of cars and they are very good with their work. I'm guessing I should take it to them? I don't want to get charged an arm and a leg for this.
Old 04-06-2006, 07:29 PM
jeffcoslacker's Avatar
jeffcoslacker jeffcoslacker is offline
Lactose the Intolerant
Spray a little water or WD-40 on the A/C belt while it's running with the A/C on, and see if the noise changes or goes away. If it does, you just have a loose or glazed belt that's singing.
You made three mistakes. First, you took the job. Second, you came light. A four man crew for me? F**king insulting. But the worst mistake you made...
...empty gun rack.
Old 04-19-2006, 02:04 PM
Thanks., I'll give that a try. To add, it doesn't do this all the time. Particularly when the car is sitting idle at a light with the A/C on full blast. Once I start to move, the noise gets a bit louder then goes away completely.
