Old 04-05-2006, 11:37 AM
vairman vairman is offline
97-F-250 Powerstroke Dies at idle??
I have a intermittent problem that when I come to a stop the engine dies, it will start right back up but it's so annoying.... Help please!
Thanks
Old 04-05-2006, 03:16 PM
wwwildman wwwildman is offline
Re: 97-F-250 Powerstroke Dies at idle??
Thanks
A friend of mine had this same problem on his 2003 with the 7.3 Liter. The Ford dealer said that a metal crimp on the wiring from the Cam Position Sensor would ground out on the engine occasionally and cause it to die. Sounds like the same thing as you described.
Old 04-09-2006, 09:24 PM
brattzzzzz brattzzzzz is offline
might want to check the fuel filter
maybe your injectors
Old 04-10-2006, 10:51 PM
AmysTrooper's Avatar
AmysTrooper AmysTrooper is offline
Sounds like a CPS. (cam postion sensor) starting to go. I would start there, very common..
