I have a 85 caprice that sucks oil into the air cleaner and the driver side of the engine only has 50lbs compression and bleeds down from there on all 4 cyclinders.I changed head gasket and there was no change. If the head is warped will 350 heads work on this engine? And what do think maybe the cause of this problem? Cylinder walls look good.
Re: 305 heads
When you get it together and run your compression check, squirt some oil into the cylinder (a couple teaspoons) and if you see improvement, you have worn rings.
1988 9C1 - Modified LM1 @ 275HP/350TQ - TH700R4 - 3.08 8.5" Disc Rear - see it at http://www.silicon212.org/9c1! 2005 Crown Vic P71 - former AZ DPS - 4.6 liters of pure creamy slothness! 1967 El Camino L79/M20 old school asphalt raper Remember - a government that is strong enough to give you everything you need, is also strong enough to take everything you have. |
Re: 305 heads
what he said, dammit silicon you beat me to it
Formerly Blownalcoholboy 1986 Z28, 400ci SBC, Twin borg warner billet S467 turbos, Reid case powerglide, Moser 9". Holley EFI, Boost Leash. 950RWHP on pump gas, 1200rwhp on race gas (22 psi) Best ET 1/4: 8.35 @ 170mph (275 drag radial) Best ET 1/8: 5.44 @ 132mph (275 drag radial) Best 60': 1.31 on the back tires (275 drag radial) AF User Rules/Guidelines http://www.automotiveforums.com/vbul...uidelines.html |
