Old 04-04-2006, 11:24 PM
4twenty's Avatar
4twenty 4twenty is offline
'89 CRX motor SWAP help!!
ok my boy has a 1997 acura EL 1.6 VTEC motor + tranny and i'm wondering if the mounts align with my CRX mounts?? will it bolt right in?
Old 04-05-2006, 12:04 AM
CRXperiment's Avatar
CRXperiment CRXperiment is offline
Re: '89 CRX motor SWAP help!!
na man you need b-series mounts before you can do anything else. You should read up about swaps. Is it a b18c1?
1989 Civic STD - sold
1991 CRX Si - current
Free Service Manuals: http://hondatech.info/
Old 04-05-2006, 01:52 PM
4twenty's Avatar
i don't know what the engine code is but its a 1.6 litre so i'm pretty sure it's not the b18, i do know that it has 127hp though. >> http://en.wikipedia.org/wiki/Acura_EL i've tried to look up the engine code for it all over but i can't find it... and what if i do get the B-series mounts, then can it work?
Old 04-05-2006, 02:41 PM
turtlecrxsi's Avatar
turtlecrxsi turtlecrxsi is offline
Send a message via AIM to turtlecrxsi
I bet it's the same as the Civic EX engine d16y8 1.6L SOHC vtec ~130hp. If so, it should bolt right up. You will need to wire up vtec by either an rpm activated switch and/or VAFC or go OBD1 with a p28 ecu. The d16y8 engine is OBD2 but you can use the OBD1 sensors...
Also, the tranny will work but you'll need a cable to hydro conversion or just use the one currently in your CRX.
2008 KIA Spectra5 SX
2010 Honda CR-V EX
Old 04-05-2006, 03:22 PM
4twenty's Avatar
won't the vtec automatically work if i get the matching ECU to the engine, possibly from the same guy? and can you go into more detail about the whole tranny situtation? what type of tranny does my CRX have, and what exactly do i gotta do to match up the EL one?
Old 04-05-2006, 05:12 PM
FrodoGT's Avatar
FrodoGT FrodoGT is offline
No because your stock wiring harness does not include the wires for the vtec solenoid and pressure switch. And no, putting an acura harness will definately not work...
Cheap, Fast, Reliable..Pick two
Current project:
Rio Red 91 hatch.
A6/Z6 build, Hondata S300, Tokico illumina/Ground Control.
"I'd rather run 12's on steelies than 15's on rotas."
Old 04-06-2006, 08:12 AM
CRX has a cable clutch tranny. OBD2 Acura has hydraulic clutch tranny. A CRX Si tranny is supposedly better for vtec because of the short gearing, but I believe the DX tranny is similar minus the final drive.
2010 Honda CR-V EX
Old 04-07-2006, 12:18 AM
Concept Tuning's Avatar
Concept Tuning Concept Tuning is offline
The EL's came with D16Y8's
