i have a '97 camaro with a tuned port 3.8 engine. the heads were cracked when i bought it so i replaced with reman. ones, so far so good. when i got it back running the lifters were making their little noise and would not shout-up after driving it for 150 miles and several tricks so i relaced all of them. got it running again the lifters are quite but there is still a ticking sound coming from the front of the engine that goes faster when idled up. could this be a bad new lifter, or timing chain slaping or
????. any and all help will be meet with a million dollars or thanks, paul l. brown
Re: '97 camaro engine noise(coming from the front of the engine)
Have you replaced the timing chain before? how many miles on it?
if there are a lot, then you might just want to replace it to be on the same side as it is just normal maintinance anyway(do it yourself a save a couple hundred $$$, you can probably buy all the parts for less than $70) Make shure you have all the parts ahead of time including the chain guide/tensioner. If your timing parts are worn, then replacing them will make a world of difference. But first, check for any exhaust leaks... |
ya, just pull the timming cover off and take a look, but first like malletslinger said check for exhaust leak.
95 Z71 Silverado 4x4 ext. cab Mods- Flowmaster Exhaust,Intake |
don't overlook the water pump, it's that itme of year.
Otherwise, you did soak the lifters before reinstalling right? Also sure you hit the torque specs on the rockers? |
i did soak the lifters before the install and also there could be an exhaust leak , i will ckeck that to day. as far as tourqe specs on the rockers i was told by autozone that there are none. i do think it is the timing chain. the car has 150,000 miles on it.
Yeah chain or manifold leak, very possible then.
