Old 04-04-2006, 11:00 PM
irhino2 irhino2 is offline
Send a message via MSN to irhino2
Exclamation I need help with my new Stealth
I bought a 91 stealth earlier this week, and I am having a couple issues. I think my main concern at this time is the clutch. I'm not sure though because I've never seen a clutch act like this. First, I get a little grind going into 3rd at medium to high RPM's. Second, the clutch is grabbing the last 1- 1 1/2" of the pedal. The pedal is almost all the way out before it starts to grab. There isn't any lag time in the shift either. It's either in gear or out which makes it hard to control shifts. It feels like the car slowly gains power after the shift. I seems to get worse the more I drive it. It almost has 175k miles. I am up in the air as to the real reason for the problem. Could it be the clutch, slave cylindar, clogged fluid line, or a bad tranny??
I'd appreciate any help I can get.
Thanks,
Last edited by irhino2; 04-04-2006 at 11:01 PM. Reason: needed to allow more posts
Old 04-04-2006, 11:06 PM
Igovert500's Avatar
blue + red light magnet
Re: I need help with my new Stealth
The clutch issue could be a few things.
But the grinding is the synchros. They are old, and commonly get worn and cause grinding issues. They can be purchased at Kormex pretty cheaply and you can find a local shop to swap them. Youngvr4 had this done awhile back, so he might be able to give you specifics on that.
As far as the clutch, have you checked the fluid levels? Have you toyed with the adjustment screw at the pedal? Are you sure it's a stock clutch and not some aftermarket one?
96 3000gt vr4
-K&N FIPK
-Proboost mbc
-Greddy type-s
-ATR downpipe
-no cats
Old 04-04-2006, 11:11 PM
Gateway's Avatar
Gateway Gateway is offline
I have an RPS streetmax clutch (used to have the 6 puck) and both grab pretty good, and are a lot stiffer to push in than the stock clutch. The 6 puck was either grab or not. It was very touchy.
'92 3000GT VR4
Current Mods:
K&N FIPK
RPS Streetmax clutch
Rebuilt tranny
Free Boost Mod
Maximal Performance Solid Motor Mounts
Pictures and Videos of my car
Got a question about your auto insurance? I'm an insurance agent, ask away.
Old 04-04-2006, 11:28 PM
Stealthee's Avatar
Stealthee Stealthee is offline
Your worst nightmare
I second the comment on checking the adjustment rod.
Old 04-05-2006, 06:44 AM
I just did some brake work a couple days ago. So, the fluid level was fine. I actually had to take some out after replacing the pads.
Is this adjustment rod you are talking about right at the clutch pedal?? I didn't even know it was equipped with that kind of adjustment. Are there any adjustments at the tranny itself for these things?? As far as the clutch itself, I have no idea if it is stock or not. The guy that sold me the car wasn't even the one who owned it. He couldn't tell me alot about the car. He only talked about a couple recent repairs. The owner had moved to Cali, and he was just wanting to get rid of it. So, he had a friend sell it for him.
What about the fact that the clutch seems to get worse the more I drive it??
I had an idea the syncros were probably bad. You have to rebuild the tranny for that. Don't you??
Rhino
PS - Would anyone have any idea where I could track down a Haynes manual or maybe a good website that has the cars specs and mechanical steps for repairs??
Old 04-05-2006, 06:54 AM
Stealthee's Avatar
There is no Haynes manual.
Also the clutch fluid has its own resevoir. It doesnt share one with the brake fluid.
Old 04-05-2006, 07:03 AM
Where is the clutch fluid res.?? I hadn't seen an extra res anywhere!! It looks like the line is running right to Master cylinder from what I could tell.
Do you know of any manuals for a 91 stealth??
Rhino
Old 04-05-2006, 07:49 AM
talskinyguy talskinyguy is offline
Send a message via AIM to talskinyguy
www.3sxperformance.com sells manuals.
The clutch resivoir is to the right of the brake booster if you are looking at the engine bay from the front of the car.
A few "bolt on" mods, a couple "cut, smash, hammer, weld, etc" mods, and a couple "why the hell do I need this/what the hell is this" weight reductions.
Old 04-05-2006, 04:03 PM
sLADe781 sLADe781 is offline
Rhino
http://www.manualcd.com/
Old 04-05-2006, 04:08 PM
Originally Posted by sLADe781
Any idea how much they are charging for this, or which option would be for the Stealth?? I'm guessing the 3S.
They have online ordering disabled. So, I'm just curious as to the cost.
Rhino
Old 04-05-2006, 04:10 PM
I found the res.!! The level actually looks ok. It was between the fill lines, but a little closer to the min. line. So, I am going to add more to it. I don't think it will make a difference since it isn't that low. That takes brake fluid right?? Kind of a stupid question, but you never know.
I am planning on looking for the clutch adjustment at the pedal tonight. I would appreciate any advise I could get on making that adjustment. I'd hate to make it worse!!!!
Rhino
Old 04-05-2006, 07:27 PM
Igovert500's Avatar
Yes it takes brake fluid. Be sure not to spill any on paint, as it will ruin the paint.
The adjustment rod is by the clutch pedal. You break the locknut loose, then spin the rod to adjust the pedal to your liking.
You may also want to bleed the clutch afterwards. Find the bleeder nipple, hold a bottle up to it, loosen the bleeder, have friend push in pedal, let some fluid with air flow into the bottle, tighten bleeder, have friend lift up pedal after the bleeder is closed. Repeat until satisfied.
96 3000gt vr4
-K&N FIPK
-Proboost mbc
-Greddy type-s
-ATR downpipe
-no cats
Old 04-05-2006, 08:09 PM
youngvr4's Avatar
youngvr4 youngvr4 is offline
STREET RACING GURU
here's the site for the synchro's
you dont need to rebuild the trans, just install the blocking rings
http://www.kormextrans.com/index.php
Old 04-05-2006, 08:31 PM
Rhino
I paid about $30.00. It'll be cheaper than buying the actual manual that's for sure. As far as what's on the CD, go to the FAQ section. And yes, you would be buying the 3s CD.
Old 04-05-2006, 08:33 PM
Young, I've heard you talking about the blocking rings before...are the blocking rings the same thing as the synchros or 2 different things!?!
