Go Back   Automotive Forums Car Chat > Nissan > 240SX | Silvia | 200SX(RWD) | Gazelle | 180SX
Old 07-11-2002, 07:56 PM
ivan282 ivan282 is offline
Send a message via AIM to ivan282
300zx parts on a 240?
i found a salvaged 91 zx TT at a junk yard and im wondering is there anything i can take off that car that will fit on my 95 240 that will help performance.
Old 07-11-2002, 09:48 PM
Bean Bandit's Avatar
Bean Bandit Bean Bandit is offline
I'm not shure but I think you can use the fuel pump and the brakes.:bandit:
Finaly got my RS13 now need money to mod it
Fun is not a straight line. AFs member #299, loyal european support since 02/2001.
Old 07-12-2002, 11:31 AM
NISSANSPDR's Avatar
NISSANSPDR NISSANSPDR is offline
Send a message via AIM to NISSANSPDR
Also can use the fuel filter, radio, shift knob...maybe even the steering wheel.
Also I think you can use the adjustable tension rods...not sure but I think.
Not to mention you can use the VG30DETT or VG30DE or any Z31 engine...or Datsun engine too.
Yours truly,
Gabriel
Old 07-12-2002, 01:52 PM
with enough $$$ you can use everything
Old 07-13-2002, 02:23 AM
Fliquer Fliquer is offline
Send a message via AIM to Fliquer
You can use the brake parts, but only if you're 240 is a SE model. The ZX uses the same 5 bolt hubs as the 240sx SE but the base 240 uses 4 blot hubs.
Or you could salvage some 5 bolt hubs from a wrecked SE and put them on your car.
Isitcontagious.com
'92 S13 coupe
KYB adjustable struts + Whiteline springs
Urethane bushings in all control arms and subframe
Cone Filter
Next up: LSD
RIP #05
Old 07-13-2002, 03:06 PM
LoveSick LoveSick is offline
There is a lot of thing you can use. If you have a S14 4 lugs 240SX, you can basically use everything.
Here is a list of what you can use as a direct bolt on:
- Tension Rod
- Fuel filter (If in good condition, if not, buy a new one for really cheap)
- Throttle Body. Great sound for your ride. Just clean it thouroughly before install
- 5 lugs hubs
- Front and rear discs, pads, lines, and calipers (rebuild and clean them before putting them on your 240sx)
- fuel pump
- RearEnd, but require too much modication.
Old 07-18-2002, 06:46 PM
j240 j240 is offline
Talking lights?
Were the headlights anygood????????
Old 07-20-2002, 05:41 PM
the headlights? no they are both destroyed.
thanks everyone for your input!!!!
Old 08-10-2002, 04:28 AM
Skyline240 Skyline240 is offline
Send a message via AIM to Skyline240
everybody forgot one important part the lsd from the 300z if thats in good condition i would pick that up that could keep the ass on the ground and put all the hp and torque where it should be
What the hell is a Skyline240?
R33 tune up in the States, which 300zx parts work? R33_Drift Maintenance 6 07-31-2004 05:00 PM
300zx parts BigDanTheMan 240Z | 260Z| 280Z | 300ZX (Past Z Cars) 4 10-29-2003 05:02 PM
90-96 Nissan 300ZX Parts needed HELP toysup Classifieds 0 09-19-2002 11:55 AM
1990 or Above 300ZX Parts for Sale JPVB Classifieds 0 03-02-2002 06:09 PM
1990 or Above 300ZX Parts for Sale JPVB Classifieds 1 03-02-2002 06:06 PM
