Old 04-04-2006, 09:47 PM
95UNDERGLASS 95UNDERGLASS is offline
Angry One More The Temp Gage Goes Up And Down More Up Then Down
MY GRANDPRIX TEMP GAGE GOES UP AND DOWN MOSTLY UP. I DROVE 30 MILES TODAY THE GAGE WENT UP AND DOWN MOSTLY UP BUT NOT 210 MAYBE 220 I HAVE THE FANS RUN DIRECT I CHECKED THERE WORKING FINE, . WHEN I GOT OFF THE INTERSTATE I WAS AT A STOP LITE AND IT HIT 260 I QUICKLY TURNED OFF THE CAR, GOT TO A GAS STATION OPEN THE HOOD AND TOOK THE RADIATOR CAP RIGHT OFF IT WAS NOT HOT AT ALL. I ADD SOME WATER BUT IT DIDNT SEEM TO MAKE MUCH OF A DIFFERENCE, BUT IT DIDNT HIT 260 AGAIN. MY QUESTION IS---IS IT THE THERMO STAT, SENDING UNIT, OR WHAT? IF ANYONE CAN HELP PLEASE LET ME KNOW. I AM GOING TO CHANGE THE THERMO STAT. ITS A NEW RADIATOR AND SEEMS TO HAVE GREAT FLOW. I DO ALSO KNOW ITS NOT THE GAGE ITS SELF. BUT I'M JUST STUMPED ON WHY THE GAGE GOES UP AND DOWN. IF YOU CAN HELP PLEASE LET KNOW THANKS KYM
Old 04-05-2006, 08:02 AM
GTP Dad GTP Dad is offline
Pontiac Guy
Re: One More The Temp Gage Goes Up And Down More Up Then Down
Changing the thermostat should cure the problem. It sounds like it is sticking closed. The up and down of the guage indicates that the thermostat was working to a certain extent but when the car hit 260 and there was no hot water in the radiator that indicates it has failed in the closed position. I would also change the radiator cap and make absolutely sure you get all the air out of the system.
Old 04-05-2006, 08:32 AM
richtazz's Avatar
richtazz richtazz is offline
stupidity should hurt
Still waiting for the "good old days" I'll get to bore my future grandchildren with!
Old 04-05-2006, 09:36 AM
wlkjr's Avatar
wlkjr wlkjr is offline
Mine did the same thing after changing the thermostat and water pump. I had to purge the air out of the system and then it settled down to a normal condition.
97 Grand Prix GT
360,000 miles as of 02-01-09
391 000 miles as of 11-17-11
400,000 miles as of 3-15-13
01 Duramax/Allison
07 G6 convertible
