Old 04-04-2006, 10:18 PM
dustinlmiller13 dustinlmiller13 is offline
Question Help with intake heat crossover?
I am doing a whole top end swap on my 1980 lt camaro when i run into a problem. My brother says if i want more performance out of my small block chevy then i should block the heat crossover in the bottom of the intake manifold. The manifold is an Edelbrock Performer, not the RPM model, and I dont have enough cash to spend on another intake. How would i close up the crossover on both sides without messing up the sealing properties of the intake? Please help me.
Anything is possible through Christ our Lord.
1980 Camaro: Base coupe sleeper with 350 4bolt main (stock bore, double humps, 480 lunati cam, flowtech headers). Stock 2.73 open rear (changing next month to 4.10 mini spool).
Old 04-05-2006, 09:50 AM
wrightz28's Avatar
wrightz28 wrightz28 is offline
is bring'n sexy back
Re: Help with intake heat crossover?
Removing as much heat as possible from incoming air does increase performance by means of introducing cooler denser air. However in this instance I really think the gains are nearly negligable. Already switching from the cast iron intake to the performer is enough of a gain in it's self.
Old 04-05-2006, 03:15 PM
Jcrane88 Jcrane88 is offline
Send a message via AIM to Jcrane88
im wanting to get a performer intake....just curious what are the gains i'd be looking at? ( dont mean to hijack)
1984 Camaro 5.7L 350
700R4
Holley 650 Cfm
Edelbrock Performer Intake-Manifold
Crane Cams Duration @ .050": 204/214 Lift:420/442
Summit HEI Distributor
Hedman Shorty Headers
Hedman Y-pipe
Dynomax Turbo cat-back
NOS Decal
VTEC Decal
Old 04-05-2006, 03:19 PM
wrightz28's Avatar
Same thing, better heat dissipation, a huge weight loss, better air flow characterisitcs just to name a few. A performer is a decent cheap upgrade.
