Go Back   Automotive Forums Car Chat > Chevrolet > Avalanche | C&K | Silverado | Suburban | Tahoe > Tahoe
Old 04-04-2006, 09:12 PM
budbowl7 budbowl7 is offline
A/C Problem
After using my Tahoe on our first day of hot weather for the year, I noticed that my A/C is not cold at all. I have owned the truck about 4 years and have never recharged the system or anything.
The compressor clutch runs for 1 second and then stays off for about 11 seconds. I hooked up a guage I have to it and the pressure builds to 45 psi when the clutch is not spinning and drops to about 10-15 psi when it does spin for that 1 second. The pressure then begins to build again when the clutch stops and it just cycles through this over and over. Can anyone offer me some advice? I don't now much about this A/C stuff and would prefer to do the work myself if possible.
Old 04-10-2006, 06:08 PM
horse482's Avatar
horse482 horse482 is offline
AF -Advisor
Re: A/C Problem
It sounds like the charge is low, or it has a bad cycle switch/low pressure switch.
NO 4 N JUNK
1994 GMC K1500 XC 5.7L
2008 Chevy Impala LTZ
Old 04-11-2006, 03:37 PM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
Re: A/C Problem
You are out of gas.
If he system has been that way very long you will need to pump it out and run a vacume pump on it to remove any moisture and check for leaks.
If it does not hold good vacume you have a leak. Look around for oily spots.
If no leaks recharge with the proper amount of freon and with a proper recharging gauge set that has high and low gauges both so you can watch both high and low pressure.
Also use the correct R-134-a freon and no stop leak crap or any blend freon that has them butane/propane mixers.
MT
MT
Old 04-13-2006, 03:49 PM
swp5767's Avatar
swp5767 swp5767 is offline
Re: A/C Problem
The 45psi reading, is that the high or low side. If thats the low side (which I suspect) what is the high side reading?
97 Tahoe 2WD LT (mine)
00 Astro (wife's)
89 S-10 p'up (daughter's)
72 VW Beetle (mine too)
Old 04-13-2006, 04:01 PM
MT-2500's Avatar
AF - Advisor
Re: A/C Problem
He said that was the pressure with compresser off and droped way down when compreser kicked in. Sounds like low side reading with low freon.
But as you say we need the high side reading to.
MT
MT
Old 04-23-2006, 09:10 PM
rumblefish73 rumblefish73 is offline
Re: A/C Problem
Hey guys, I have a 2001 Tahoe with rear A/C and i've searched the forums and I'm trying to find out what my low side pressure should be? My Tahoe won't cool at all at idle... The low side pressure is 60-75psi when the compressor is on and i it cycles off while sitting idle and goes up to 125-130psi... When traveling down the road today it was about 80 degrees outside and the front vent temperature was about 35 degrees measured with a decent clip-on a/c vent thermometer so I think it's doing a pretty good job. Sounds like some of you have low sides around 45 psi with no cooling so I'm guessing i'm ok but wonder if i could put in half a can to get it to cool better at idle?
Old 04-24-2006, 08:42 AM
MT-2500's Avatar
AF - Advisor
Re: A/C Problem
No. Do not ADD untill you get all pressure readings.
Get the low and high side readdings a idle and at 2000 rpm with compresser runnimg and post back all pressure readings.
Also read my upper post .
MT
MT
