Go Back   Automotive Forums Car Chat > Oldsmobile > Aurora
Old 04-04-2006, 08:37 PM
djdrastic31 djdrastic31 is offline
M7 95 Aurora Stalls when idle
My 95 aurora has 150k on it, it stalls when i take my foot off the gas, the rpms drop real fast, so i always have to give it a lil gas to stay alive. Also sometimes when i take my foot off the gas, instead of the rpms dropping, sometimes the rps stay up, and the car continues to give it gas, even though my foot is off, and wont drop back down until I hit the break. Also, sometimes when I start my car back up, the RPM's jump up to 3000 without me hitting the gas. Anyone know what could cause this? And has this happened to anyone before?
Old 04-05-2006, 12:08 AM
Smoothe LJ Smoothe LJ is offline
Re: M7 95 Aurora Stalls when idle
sounds like fuel pressure regulator. not a very hard fix, actually probably tha easier fix for the aurora
Old 04-05-2006, 12:34 AM
is it something one could fix themselves with minor knowledge of cars without a guarge... ? and is there anything I can do to find out if that is the problem or not?
Old 04-05-2006, 06:23 PM
parts68 parts68 is offline
do you have a service engine light on?
I would suspect the Idle Speed Controller.
Old 04-05-2006, 06:34 PM
no the engine light is not on, but who knows how many people owned the car, and if someone cut the light or not. Maybe I can have autozone hook it up to the computer and find out
Old 04-05-2006, 08:05 PM
I dont think they can scan an OBD1 system
Old 04-07-2006, 05:26 PM
tjm's Avatar
tjm tjm is offline
Idle speed control sounds likely as mentioned above. However, be sure to check all your vacuum lines; usually the PCV valve elbow rots out. Also, snug down the intake manifold too; use a 10mm deep socket over the engine cover studs.
Another possible is the mass airflow sensor; similar issues and sometimes will not set a code.
Do the cheap stuff first.
'97 Majestic Teal Metalic, 233,000 miles of smiles
Member of the AURORA CLUB OF NORTH AMERICA
