Old 04-04-2006, 08:29 PM
shaws5 shaws5 is offline
evap system problem
I have a 2001 dodge grand caravan that the mil keeps coming on. I have had the code cleared 2 times and it comes back but not right away. The last time i had it erased the service man told me to put a new gas cap on it and I did but it came back on after about 3-4 weeks. I do not remember what the code was but it was the evap system i think it was a small leak. LET ME KNOW IF ANYONE KNOWS WHATS GOING ON MY WIFE IS GETTING MAD WITH THE MIL ON!!!!!!
Old 04-05-2006, 01:30 AM
Stevo2's Avatar
Stevo2 Stevo2 is offline
Re: evap system problem
Gotta have the error code number to pin it down any further.
Jack of all trades...Master of none!
Could someone please fix my Instant Email Notification?
Please get back to us with your fix!
Why did you buy a $40K vehicle and not a $100 Factory Service Manual?
Old 04-05-2006, 03:15 PM
RIP's Avatar
RIP RIP is offline
AF -Advisor
There's two ways to get the code: >> (apply to a 2001?) Cycle your ignition switch from off to on (not start) three times leaving it on the third time. Watching the MIL light, count the sequence of flashes. A code 23 would be flash, flash, pause, flash, flash, flash. >> Second way is to go to Autozone or a similar business and have them download the codes with a scanner. They can tell you exactly what the codes mean and...it's FREE. Worst way is to go to a dealer and pay for it.
I read somewhere on this forum that the MIL light could come on if you have the gas cap off with the engine running. I hope the love of your life is refueling with the engine off.
Old 04-05-2006, 08:53 PM
I did the cycle of the key and the codes came up on the odometer and they were p0442 and p0445, so if anyone knows what they stand for please let me know!!! ther was one more after checking again p1684
Old 04-05-2006, 09:24 PM
Stevo2's Avatar
I dont see P1684..other codes look like maybe a bad hose or leak detedtion pump.
SYMPTOM P0442 - EVAP LEAK MONITOR SMALL LEAK DETECTED
WHEN MONITORED
See DRB III
SET CONDITION
See DRB III.
POSSIBLE CAUSES
EVAP system hoses or wiring damaged
EVAP system component leaking
Leak detection pump leaking
EVAP leak monitor small or large does not reoccur
P0445 Evaporative Emission Control System Purge Control Valve Circuit Shorted
SYMPTOM P0455 - EVAP LEAK MONITOR LARGE LEAK DETECTED
TEST NOTE
This symptom is diagnosed using the test P0442 - EVAP LEAK MONITOR SMALL LEAK DETECTED.
WHEN MONITORED
See DRB III
SET CONDITION
See DRB III.
POSSIBLE CAUSES
