Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Engine, Transmission and Drivetrain
Engine, Transmission and Drivetrain Discuss Engine, Transmission, Drivetrain, and all other performance modifications here.
Old 04-04-2006, 08:04 PM
Nayr747's Avatar
Nayr747 Nayr747 is offline
FP T25/28 17 psi actuator
Did a couple quick searches but didn't turn up anything. Just curious about this. http://linux.forcedperformance.net/m...=WAT28DSM17psi
Couple questions: Why would this be any different than using a mbc at 17 psi? Why does it show a pretty large hp increase over an mbc at 17 psi? And isn't 17 psi a little high for the T-too small? At twice as much as a mbc, and less adjustability, I don't see why they are selling this.
'99 GSX, 5-speed, 60k miles: Greddy filter / RRE uicp / 1g bov / Autometer boost gauge / Injen-copy intake / Megan DP (not installed)
Coming soon! Thx to Blackcrow & nova1313! http://dsm-one.org/
Adopt pets in need! http://www.petfinder.com/
Old 04-04-2006, 08:21 PM
crunchymilk55's Avatar
crunchymilk55 crunchymilk55 is offline
Send a message via AIM to crunchymilk55
Re: FP T25/28 17 psi actuator
"Run 013 was the stock actuator with the boost turned up to spike to 17psi and drop to around 12psi. Run 023 is the New 17psi actuator running a steady 17ps"
12psi vs 17psi, it's an unfair comparison
They're probably selling it for people who want a stock appearing engine bay,(the people running T28's)
To just about everyone, they see a stock turbo running stock boost, no mbc.
now - 2000 civic
soon - 2002 is300
Old 04-05-2006, 07:02 PM
Nayr747's Avatar
Thanks crunchy, that makes more sense.
Old 04-05-2006, 11:05 PM
no problem
now - 2000 civic
soon - 2002 is300
Old 04-10-2006, 11:31 PM
kjewer1 kjewer1 is offline
AF - Advisor
The reason to upgrade the actuator is to keep the flapper from blowing open prematurely. The t25/28 has a very resitrictive turbine housing, raising pressure on the manifold side of the flapper, which then pushes it open (force = pressure x area). Another reason is to allow EBCs to run more boost (most do double WG spring pressure), but this is unlikely to be a reason to do this on such small turbos. Also, running more than double spring pressure with an MBC can lead to very unstable boost.
I installed a Forge 17 psi actuator on my EVO8 turbo. No change in the max boost I could run, but it was worth the 150 bucks to rule out a flapper blowing open problem. The EVO8 turbo seems to be designed very well since it doesn't blow the flapper open at up to 28 psi.
Kevin Jewer
RWD Talon - 7.92 at 180
Mightymax - 10.7 at 125
Old 04-11-2006, 06:55 PM
Nayr747's Avatar
Ah, I see. Thanks Kevin.
