Old 04-04-2006, 06:59 PM
74lt 74lt is offline
99s-10 blazer 4.3w cyl 2and 3 misfire plague
Hello,
working on a 99 chevy s-10 blazer 4x4 engine code w with 80k replaced distributor cap and rotor, replaced spark plugs, plug wires.
still have misfire on cyl. two and three. poppet injectors blasted out at gm dealer, . ran fine for three days, started misfiring again.
fuel pressure 3-5 pounds low, swapped mass air flow sensors , no change.
replaced injectors 2 and 3 , no change.tried different plug wires no change.
miss is most noticable in park at light throttle.
codes are po300 random misfire.??????
Old 04-04-2006, 09:44 PM
dmbrisket 51's Avatar
dmbrisket 51 dmbrisket 51 is offline
Send a message via AIM to dmbrisket 51
Re: 99s-10 blazer 4.3w cyl 2and 3 misfire plague
is there a cam/crank code?
Old 04-05-2006, 12:32 AM
RahX RahX is offline
I've seen those crazy caps arc internally. Might try changing out the cap again. Take it back and get another.
Old 04-05-2006, 02:35 PM
Cam1959 Cam1959 is offline
I presume the poppet injectors you say gm dealer cleaned out and got good running for few days, are the fuel injectors ?
Even though you changed them, something seems interfering with light draw at low rpm. Could there be deposits in injector feed or gas lines ? Or is it carboning them up in cylinder by running to rich ? choke ?
1983 S10 4WD carbed 2.8L automatic w A/C
Old 04-06-2006, 11:33 AM
dewaynep dewaynep is offline
I just posted in the other misfire post. Do youself a favor and get an AC/Delco distributor cap and rotor if you don't already have one. Don't use the aftermarket caps and rotors they have a tendency to cause p0300 general misfire codes. The misfires usually occur at cruising speed on a level highway. You state the code as p0300 but think the misfire is in cylinders 2 and 3? There would be codes p0302 and p0303 stored if that were the case. Try an AC/Delco cap and rotor directly from the dealer.
