Old 04-04-2006, 06:51 PM
JROB46 JROB46 is offline
Question 1994 Silverado, Bad Vibration
I am having some serious vibration in the front end. The whole front of the truck, the steering wheel and dash board shake like hell between 65- 80 MPH. Under 60 it is faint, over 80 it is smooth(until I let my foot off the gas). I have just put on new tires, an alingnment(after putting on new pitman arm and tie rods), new wheel bearings and brakes. The vibration did not get any better(actually feels worse). Any suggestions as to what else it could be? Thanks in advance for any help.
Old 04-04-2006, 06:55 PM
maxwedge maxwedge is offline
A990 racer
Re: 1994 Silverado, Bad Vibration
Check drive shaft u joints.
Old 04-04-2006, 07:37 PM
Thanks for the reply. I don't think it is the u-joints. I just replaced them about 8 months ago. The vibration is a recent developement. I did check them again and all seems good and tight, no slop. Thanks again.
Old 04-04-2006, 07:50 PM
gmtech79's Avatar
gmtech79 gmtech79 is offline
You also need to completely remove the shaft and turn the u-joints by hand and feel for roughness. I would check the tire balance again and do a road force balance even. I have seen brand new tires be bad.
Old 04-06-2006, 07:38 PM
I removed the drive shaft and the u-joints feel good. Just like new. I just had new tires put on the day before my post. The alignment was done the same day too. Can you think of anything else it may be? Thanks again for your time.
Old 04-06-2006, 08:30 PM
gmtech79's Avatar
I'm guessing this is a 2 wheel drive?
Old 04-06-2006, 09:32 PM
Yes it is a 2 wheel drive, with a 4spd with OD manual trans.Sorry I didn't mention that sooner.Any thoughts?
Old 08-26-2009, 03:39 PM
kid7688 kid7688 is offline
i know your post was a long time ago
hope it was the balance of the tires if you put a new set on
let me know what the solution was and where you had your work done
Old 12-02-2009, 09:58 AM
PIT BULL PAPA PIT BULL PAPA is offline
i had the same problem the sway bar was broke.
