Old 07-11-2002, 04:48 PM
NuEra's Avatar
NuEra NuEra is offline
Banned
Exclamation check engine HELP!
I have a civic, which I took the heatshield off of the stock headers to clean. when I put it back on I forgot to reconnect the O2 sensor to the clip and I started the engine and the CHECK ENGINE light came on. I imediately remembered what I did wrong and turned the car off and reconnected. I started again and it still came on. I even left it off for quite some time but it stays on. What do I need to do, does a profesional have to reset it or something?
Old 07-11-2002, 07:41 PM
NuEra's Avatar
Banned
I reset it by taking out the fuse but I just want to make sure that the light was supposed to stay on even though the problem was solved. I mean when I reattched the O2 should thelight have gone out?
Old 07-12-2002, 01:18 AM
Si2000 Vtec Si2000 Vtec is offline
Send a message via AIM to Si2000 Vtec
Nope, your okay. Most of the time, the light doesn't go off once you fix the problem until you reset the ECU, of which you did. (remove the radio backup fuse or disconnect your battery for 30 seconds). Your fine, nothings wrong with your car.
Old 07-12-2002, 09:34 AM
NuEra's Avatar
Banned
thanks
Check Engine Light..... Stinff Equinox 2 11-01-2010 10:15 AM
97 ram 4x4 shaking, check engine light on, one tire is wrong size cscafe Ram Pickup | Ram SRT10 2 11-18-2009 02:53 PM
1998 Malibu - check engine light jpar1983 Malibu 2 10-28-2009 07:49 PM
Check engine light on 89 cherokee hoopdaddy6 Cherokee 3 04-09-2009 05:16 PM
1994 Ranger 4cyl check engine light/ABS light wont start on cold mornings 94rangerproblems Ranger | Courier 1 03-21-2009 06:40 AM
