Go Back   Automotive Forums Car Chat > Car Buying Q&A
Car Buying Q&A Ask a question, get an answer; it's that simple. Visit AutomotiveHelper.com for useful car buying tools and research.
Old 04-04-2006, 06:30 PM
Bat Morris Bat Morris is offline
Help.. Is there a split CV joint Boot for 97 Nissan Pathfinder CV
Does anyone know if a split CV joint Boot exist
for a 97 Nisssan Pathfinder?
And where it can be found?
Old 04-05-2006, 07:02 AM
CraigFL's Avatar
CraigFL CraigFL is offline
Re: Help.. Is there a split CV joint Boot for 97 Nissan Pathfinder CV
If you do find one be aware that they are not very good without modifications. Most split boots don't seal very well at the split. Some types have little screws with holes, some have tywraps. In the cases I've experienced, it is most difficult to fasten them together tightly because they get all greasy from the lube provided. I've experienced tearout around the holes after some usage too. A clever friend solved this situation by gluing the split seam on the one for his toyota. He carefully cleaned the seam of ALL grease and dirt so he could do this. It lasted 1-1/2 years but eventually failed by breaking right next to the glued seam.
