Old 04-04-2006, 05:42 PM
steelman1958 steelman1958 is offline
OBS II Question for '96 Buick PA
I have searched this forum and elsewhere on the INet but I have not found exactly the information I am looking for. I have a 1996 Buick Park Avenue that occasionally has the engine light pop on. I brought it into the dealership and they said I just needed a new gas cap since there was a bit of a vacuum problem (intermittent), and they reset it. I bought a new cap and the problem only appears once and while (which is less than occasionally). I purchased an OBD II module to check to see if the problem is still the same and so that I can reset the light. However, the instructions don't show where to plug in the module, and I can't find the information anywhere else. I would appreciate it if someone could tell me where to find the connector on my car.
Thanks.
G.
Old 04-04-2006, 06:17 PM
maxwedge maxwedge is offline
A990 racer
Re: OBS II Question for '96 Buick PA
Look under the dash on either side of the steering column.
Old 04-05-2006, 10:27 AM
wrightz28's Avatar
wrightz28 wrightz28 is offline
is bring'n sexy back
Connecting the dots here and going on a hunch:
Trouble code says problem in evaporative emissions system accompanied by a vacuum leak, I'd be looking at the charcoal canister purge soleniod, it's a main part of the EVAP system and utlilizes vacuum
Old 04-18-2006, 07:37 PM
I found where the OBD 2 Reader connects to the PA. The plug is located under the dash, just above the brake pedal towards the steering column.
I received the code "EVAP Purge Solenoid Control Circuit". What exactly is that? How do I go about fixing / replacing it? Is this something that is fairly easy to do? I would appreciate any help this forum could provide.
Thanks.
G.
Old 04-20-2006, 09:07 AM
wrightz28's Avatar
Sorry, I missed the question on where the connector was.
The problem is either in the wiring, vacuum hose, or solenoid itself. Since it si intermittent, I would love to say it's the solenoind itself getting tired.
