Old 04-04-2006, 04:37 PM
tedkilroy tedkilroy is offline
93 Grand Voyager
I have this vechicle which has sat in my drive way since last summer and it won't turn over (start). I took the battery to autozone and thet recharged it, but that would not kick engine over. I have now replaced the front 3 spark plugs and wired, but have not attempted to take all the brackets off to replace back 3.
I was wondering before I attempt that if there was anything else I should check (loose/corrided wires). It has the 3.3 V6. Battery cables not corroded and are tightly bolted on. Spark pugs were gapped .050 and wires are on there snug.
Any suggestions appreciated.
Old 04-04-2006, 04:58 PM
jacob_00001 jacob_00001 is offline
Re: 93 Grand Voyager
is the engine turning over at all?
Old 04-04-2006, 05:08 PM
hardparts hardparts is offline
if it turns over but doesnt start then check to see if you have spark first then fuel pressure.
http://www.hard-parts.org/forum
New automotive tech site.
Just opened, come join us.
Old 04-04-2006, 11:10 PM
Someone at work suggested to use a screw driver to make contact with starter, but there is no starter, at least I did not find one after sticking my head under both sides of the tire wells. Also suggested was maybe the distributor cap had a crack or was wet. Does not have one either.
That leaves the alternator, 3 remaining spark plugs/wires and or the relay. At least that is what I have heard it called before. The black box that the other end of the spark plug wires connect to.
It sounds like it wants to start but can't, like if is flooded but not.
Old 04-05-2006, 12:49 AM
moparman58 moparman58 is offline
Check your cam and crank sensors. It won't start if they've gone bad.
