Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 04-04-2006, 03:51 PM
boyertownMidnight's Avatar
boyertownMidnight boyertownMidnight is offline
Send a message via ICQ to boyertownMidnight Send a message via AIM to boyertownMidnight Send a message via Yahoo to boyertownMidnight
idle issues with 1g
when starting the car sometimes my idle is at 600rmp like normal, sometimes when i start it up its at 2,000rpm...after driving it for a couple minutes and i come to a complete stop it will idle at anywhere from 600rpm to 2500rpm,, sometimes the car even stalls or acts like it wants to stall. I HAVE SEARCHED this issue but had nothing that could comply with the issues im having with my 1g GS N/t... im not sure where to start looking for why this could be happening,
also my engine light does not come on.
please help thanks.
Old 04-04-2006, 03:58 PM
Re: idle issues with 1g
also i cleaned out the throttle body and everything looks fine, i also replace all vacum lines, and checked all of them for leaks,
Old 04-04-2006, 04:18 PM
LouieAWDTSi's Avatar
LouieAWDTSi LouieAWDTSi is offline
Is your maf hacked?
You ever try to just adjust your biss screw?
Pcv valve been replaced(just a cheap precaution).?
Maintance been kept up on the car(probaby but just checking)?
--the Cruiser-->97 Spyder GST 5sp ---3 inch exhaust, boost/vac gauge, mbc, greddy turbo timer, greddy fmic, greddy type S BOV, 17in wheels
--the DD-->99 ACURA 3.2 TL
--Sold 92TSi AWD, 6-bolt, auto, evo 3 gt turbo with supporting mods
Old 04-05-2006, 12:36 PM
i dont know how well it had been maintained i did alot of work to it since i got it last year, but when i got it, it was in okay shape, what should i check for?
Old 04-05-2006, 12:37 PM
whats a biss screw?
Old 04-05-2006, 12:38 PM
wanaplay134 wanaplay134 is offline
Send a message via AIM to wanaplay134
do the egr valve block off and remove all those useless vaccum lines and that should help out alot it did with mine thats for sure
1992 eagle talon tsi awd
xtd stage 3 six puck/apexi 3' downpipe and exhaust/ngk plugs/taylor thunderbolt wires/manual boost controller set at 20psi/walbro 255 with rewire/autometer boost gauge/turbo xs rfl blow off valve/arp headstuds/ to4b vtrim turbo/dnp tubular manifold with o2 housing and tial 38mm wastegate/eagle rods/ross pistons/acl bearings/arp rod bolts/arp main studs/aeromotive fuel pressure regulator and all stainless lines/aem fuel rail/slowboy street front mount kit
