84 v-6 Bronco II carb
Hello all, is it worth it to rebuild the carb on these or would it be less effort to get another from a junk yard? Thank you
Re: 84 v-6 Bronco II carb
New Carb? $130
Old carb? $20 Rebuild kit? $12.50 Figuring that one you get from a junkyard would only be slightly better than what you already have, I'd just get the kit, if all your metal parts are in otherwise good condition. |
any idea how long it might take someone with medium skills?
I had no skills redoing my first one, and it only took some hours. It's taken since then to get the float adjusted properly. Now I know you don't have to replace the float if it runs right! So the worst part of the deal is getting the carb off without dropping nuts/bolts into the intake manifold. Rebuild kits come with directions, and the only way to screw it up totally is messing around with the float. Go 4 it.
I think I'll tackle it. I've replaced many carbs but never rebuilt one. Thanks for the info.
