Old 04-04-2006, 02:01 PM
chevrock22's Avatar
chevrock22 chevrock22 is offline
Replacing Rear Speakers in 95-98
How can I replace the rear extended cab speakers on my truck. It looks like it might require me to take the whole back plastic piece. Is there a trick to this or a suggestion on how to do it or where to start.
Old 04-04-2006, 02:27 PM
TaNK_Em's Avatar
TaNK_Em TaNK_Em is offline
Send a message via AIM to TaNK_Em Send a message via MSN to TaNK_Em Send a message via Yahoo to TaNK_Em
Re: Replacing Rear Speakers in 95-98
I have service manual and I’m pretty sure you have to remove the panels. I think that’s the only choice.
- Kevin
May God have mercy upon my enemies, because I won't.
- General George Patton Jr
Old 04-05-2006, 07:57 PM
BoatCop's Avatar
BoatCop BoatCop is offline
- Kevin
Yep.
I replaced mine. Had to take the rear side panels, rear back panel, and part of the top panel off. ('96 GMC)
It's kind of like a jigsaw puzzle putting it back together again. Make a mental note of exactly how they ame off.
The rear speakers are 6x9 set into the C post. I'd suggest replacing with the same size, using some kind of rubber cushion when re-installing, or maybe RTV all along the edges. Otherwise they're prone to rattle.
Alan
BoatCop
Old 04-05-2006, 08:04 PM
FearlessFoe FearlessFoe is offline
Send a message via AIM to FearlessFoe
I'm looking to replace my speakers too. I have a '92 though. I believe its pretty mucht the same interior though, but I know I have 4x6s. What holds the plastic parts on exactly? Any hidden clips that could easily break off? I've already taken the door panels off which seemed quite easy but I think the other parts might be harder.
Also, if you could give me some advice.. I'm looking for a sub box for a regular cab. I'm hoping to get a 10 inch sub on either side, along with an 800 watt amp behind the console or under the seat. I was wondering what I should do with the sub. box situation though. Would I be better off building one of my own?
Old 04-07-2006, 07:50 AM
chevrock22's Avatar
Originally Posted by BoatCop
Yep.
Are you sure there not 4x6's
Old 04-08-2006, 01:56 PM
heavyredchevy's Avatar
heavyredchevy heavyredchevy is offline
Im pretty sure they are... they didnt change much.
Old 04-08-2006, 06:36 PM
I could've swarn they are 4x6's up through 99. If you haven't gotten speakers yet, look at the audiobahn. I was just looking for new speakers for my truck and they have a 93db sensitivity @ $35 for a pair.. (a normal speaker has 90.. so this speaker produces the same sound as a 90db speaker with the volume half as high..)
Tell me how you removed the panels if you get a chance.. The fronts are cake but I'm not too sure about the back. I don't want to break anything.. Thanks!
Old 04-10-2006, 08:34 AM
chevrock22's Avatar
I couldnt remove mine either without worrying about breaking something so I just decided I would wait to see what someone had to say. I know its going to require taking off the seatbelt mounts with a torx. Also its all one whole puzzle. It should be intersesting. And thanks for that speaker tip i will look into that.
